RO Variable not responding anymore
I'm using a Unipi Neuron L203 to control the lights and screens of my house.
As i'm new to Mervis and PLC's i used a very simple setup to control about 18 lights and 2 screens.
Today i wanted to test a direct switch setting for the first time so I ran the unipi - configure module.
Right after running that and confirming the direct switch functionality works i noticed 1 of my lights was not working anymore.
I went back to the original setup and disabled the direct switch setting however that should not be interfering with the light switch that is not working anymore.L203_RO_201_w variable is not responding to any input anymore. All other RO's are responding as before.
I used autogen to generate the variables (i still need to change that if i get better at this). RO_2.01_w seems to be correctly linked to the variable.I confirmed the relay is still working by changing the default value of R0_2.01_w to true.
Any idea what i did wrong? All help is appreciated!
Hello @christophev,
please send the Mervis project to support@unipi.technology, I'll take a look at it.Best regards,
Solved. Thanks for the feedback!
