    How to change the analog transformation on xS50?
      Matt last edited by Matt
      I would like to convert an input of 0-100 into an analog out of 0-10V. I have attempted changing the values for the LinearByTwoPoints transform method as well as the Linear method and am unable to get the behavior of the output to change. The LinearByTwoPoints seems stuck at 0-10 -> 0-10V and the Linear method does not output a voltage. Is there a known problem with the transform parameters? I have deployed the project and configured the modules multiple times. The extensions I have appear to be on FW 5.60 and I am running IDE 2.1.3.
        Martin Kudláček @Matt last edited by
        Hi @matt,
        the transformation is uploaded to the PLC with deploying of the solution, not with "Configure Unipi module".
        Once you change the parameters of the transformation, any other subsequent change has to be deployed to the PLC with "Clear flash variables checked":
          Matt last edited by
          Thank you, Martin. It is working properly now. Is there documentation on this or the transformation parameters anywhere? I spent a late night trying to debug this, and even with your instructions it took a couple tries to figure out that the linear scaling factor needed to be the inverse of what I expected it should be.
            Hi @matt,
            this is described in the MervisIDE help (F1):
              Matt last edited by
              Thanks. Not sure how I missed that.
