Migrating to the latest version of Mervis from 2.0.10
So it has been a while since I last updated my UniPi but was going round updating various machines and wanted to migrate to the latest version.
I cannot however, get the digital inputs to be either found or recognised, in debug mode they always come back as false. I have tried the old solution, a brand new solution etc. but nothing wants to pick them up. The relays and temperature gauges work fine and get read and can be set (via a NOT) however I can't seem to pick them up so my code won't work.
My code is simple in that when a couple of inputs go high they should flip the relay. It has been working fine and reverting back to the original uSD card image works fine.
I assume it is something to do with the pull up\down resistor setting but I can't see anyway of setting it properly.
Hardware is a Pi 2 and UniPi 1.1
Installed the latest version of the OS Image on as well as the RT.
Any ideas please?
I thought it might have been a lack of IP address in the TCP Modbus connector so did a rebuild.
However, it started working before I changed it so perhaps the install did not complete correctly the first time around. Oh well, a somewhat frustrating amount of time wasted :)
