    After Reboot
    Node-RED
      matrixratrix last edited by
      I have a situation:
      This simple example set input directy to output, so I have two problems:
      1º If this input active then output is ON, and if I reboot the RPI, the output stay on, there is any away
      that if reboot the output turn off?
      2º if I turn on the input during boot, even when the boot is finished the output is not on, the input has to be turned off and on again for the output is on, there is any away to chek this?
      thanks
        Martin Kudláček administrators @matrixratrix last edited by
        Hello @matrixratrix,
        you have to synchronize the state at the boot time by issuing cmd:all
          matrixratrix last edited by matrixratrix
          Thank you,
          And I can do this how?
          best regards.
