    Unipi Control Panel password
      matrixratrix last edited by
      Any way to set a password to "Unipi control panel" ??
        Martin Kudláček @matrixratrix last edited by
        Hello @matrixratrix,
        the control panel should be disabled in production environments, leaving only the API port open. If you still need to put a login for control panel, follow the NGINX BasicAuth tutorial: https://docs.nginx.com/nginx/admin-guide/security-controls/configuring-http-basic-authentication/
        Be aware, that the BasicAuth sends login information unecrypted, vulnerable for eavesdropping. Employing HTTPS would be a good idea.
          @martin-kudláček said in Unipi Control Panel password:
          control panel
          Thank you,
          Where I disable control panel?
            martin_triska @matrixratrix last edited by
            the control panel is hosted by the Nginx webserver. You can simply remove the "evok" symlink from the /etc/nginx/sites-enabled/ directory. After doing this, you have to restart (or disable) the webserver to reflect this change:
            sudo su
            systemctl restart nginx
