    Simple input output map
    Node-RED
      matrixratrix last edited by
      I new on node red.
      I trying map a simple input to a relay bu Node red unsing Unipi, ai use this example:
      https://flows.nodered.org/node/@unipitechnology/node-red-contrib-unipi-evok
      The "Unipi Control Panel" tell me that the comunication is working, the WS ip is set and is connected, but for some
      reason the output is not working.
      the debug is tell me the same:
      There is there any other detail you should configure?
      Z 1 Reply Last reply Reply Quote 0
      • Z
        zdenek_jotio @matrixratrix last edited by
        @matrixratrix said in Simple input output map:
        I new on node red.
        Hello matrixratrix,
        Please can you check if the configuration of your ws node - if the "Type" is set to "Connect to" as is shown in the picture.
        This config change should solve your problem.
