    I2C bus stopped working on Axon after apt upgrade
    Scheduled Pinned Locked Moved Axon series
    3 Posts 2 Posters 1.8k Views 1 Watching
    • roberts_landoR
      roberts_lando
      After running apt-get update && apt-get upgrade axon kernel modules have been updated but i2c seems not working because /sys/bus/w1 is not present. How can I enable i2c? How can I fix this?
      Additional info:
      Seems i2c-dev module is not present
      unipi@S105-sn244:/etc/modules-load.d$ sudo modinfo i2c-dev
      modinfo: ERROR: Module i2c-dev not found.
      Manually loading the module also isn't working:
      unipi@S105-sn244:/etc/modules-load.d$ sudo modprobe i2c-dev
      unipi@S105-sn244:/etc/modules-load.d$ lsmod
      Module                  Size  Used by
      tun                    36864  2
      unipi                 102400  0
      industrialio           53248  1 unipi
      rtc_unipi              16384  0
      rtc_ds1307             24576  0
      at24                   20480  0
      Other tries:
      unipi@S105-sn244:~$ sudo fdtget /boot/sun50i-h5-unipi-axon.dtb /soc/i2c@01c2ac00 status
      okay
      unipi@S105-sn244:/sys/devices$ head /sys/firmware/devicetree/base/soc/i2c*/status
      ==> /sys/firmware/devicetree/base/soc/i2c@01c2ac00/status <==
      okay
      ==> /sys/firmware/devicetree/base/soc/i2c@01c2b000/status <==
      disabled
      ==> /sys/firmware/devicetree/base/soc/i2c@01c2b400/status <==
      okay
      ==> /sys/firmware/devicetree/base/soc/i2c@01f02400/status <==
      disabled
      unipi@S105-sn244:~$ ls /dev/i2c*
      /dev/i2c-0  /dev/i2c-2
      unipi@S105-sn244:~$ i2cdetect -y 0
      -bash: i2cdetect: command not found
      unipi@S105-sn244:~$ sudo i2cdetect -y 0
      50: -- -- -- -- -- -- -- UU -- -- -- -- -- -- -- --
      60: -- -- -- -- -- -- -- -- -- -- -- -- -- -- -- UU
      70: -- -- -- -- -- -- -- --
      unipi@S105-sn244:~$ ls /sys/devices/w1
      ls: cannot access '/sys/devices/w1': No such file or directory
      unipi@S105-sn244:~$ cd /sys/devices/
      unipi@S105-sn244:/sys/devices$ ls
      breakpoint  platform  software  system  virtual
      I2C seems working but something is wrong...
      • roberts_landoR
        roberts_lando
        @administrators any news?
          tomas_hora administrators
          The I2C is working as you can see in the output of the i2cdetect. However the ds2482 module is not loaded. You can load it on hand using
          modprobe ds2482
          and see if the address 0x18 in the i2cdetect will be marked with UU and you should see the list of connected 1wire devices in the /sys/bus/w1/devices/
