    Mervis IDE on Windows 10 works, but says "build failed" when compiling
      tomkling last edited by
      Hi there,
      I'm trying to get data from the UniPi Axon M505 through ModbusTCP to a Weintek Display, which both work fine and shall be connected over Ethernet. The Easy Builder for Weintek Devices found the device and it is possible to edit the appearance, but you would need to configure a ModbusTCP channel to be able to transfer data between the two of them. The problem is that Mervis works while programming and has the UniPi connected, but says "build failed" after the compilation. I guess it would also be possible to start unipitcp with access for network devices, but I think this would be to big of a security risk and would rather like to configure a special channel with Mervis. Does someone know what's wrong with Mervis when it's not compiling and how to fix it?
      Thanks in advance for the help.
        Martin Kudláček @tomkling last edited by
        Hi @tomkling,
        please send the screenshot of the IDE, mainly of the "Output" tab in the bottom panel. There should be information about the cause of the compilation failure.
          Hi Martin, thanks for the hint.
          It said that there was a failure in the program. I deleted that part and now it compiles fine.
