node-red startet nicht mehr
Re: How to connect Unipi 1.1 to DS18B20 Sensor
"Use Evok and Unipi node(s) to read data from sensors in Node-RED - then follow this tutorial. This is the default state.
Disable 1-Wire support in Evok (comment the OWBUS section in /etc/evok.conf), enable the module loading( add/uncomment "dtoverlay=ds2482" in /boot/config.txt), and use some other nodes (e.g. the one meant in your post) to access the 1-Wire bus."Hallo
beim auskommentieren von OWBUS und einfügen von dtoverlay=ds2482 ,startet node-red nicht mehr
Udo
@udokra said in node-red startet nicht mehr:
Disable 1-Wire support in Evok (comment the OWBUS section in /etc/evok.conf), enable the module loading( add/unWhat are you trying to accomplish with devicetrees? This is the oposite what you should do in order to have it working with Evok.
