    Upgrading to Bullseye?
    17 Posts 9 Posters 7.6k Views 2 Watching
    • lukas009L
      lukas009
      and what about OS for Patron devices? When we can expect (stable & fully functional) upgrade of Node-Red OS or OpenSource OS? Thank you
        Martin Kudláček @lukas009
        Hi @lukas009,
        it is the same issue. We will release Bullseye OS images once the support for all products is done. Looks like it could be next month.
        K 1 Reply Last reply
        • K
          knebb @Martin Kudláček
          @Martin-Kudláček
          sorry again for annoying. I am still conmsidering upgrading. Unfortunately my quastion about how I can see if it it ready for Bullseye has not been answered.
          From my point of view with the links I originally provbided it looks like it has not been upgraded up to now. Am I right here?
          Thanks& Greetings
          /KNEBB
            romainletendart
            We would also be interested in a bullseye upgrade for Unipi Neuron Series as we are currently facing issues with the systemd version that comes with buster.
            Any updates on this matter?
            Romain
              Martin Kudláček @romainletendart
              Hello everybody,
              the upgrade to bullseye is planned for March.
              • G
                gabrielsoudry
                Hello @Martin-Kudláček
                Any updates for the upgrade to bullseye?
                Gabriel
                Reply Quote 2
                • K
                  @Martin-Kudláček said in Upgrading to Bullseye?:
                  Hello everybody,
                  March has been gone now since two months.
                  So I am getting the feeling there is no effort put into getting it lifted to current stable?
                  Would be a pitty....
                  /KNEBB
                  • G
                    gabrielsoudry
                    Any news @Martin-Kudláček ? A planning for this upgrade ?
                    Gabriel
                    Reply Quote 1
                      AVsetula
                      Hello everybody,
                      we have good news!
                      All packages from the Unipi repository already have their version for Bullseye (Debian 11).
                      Unfortunately it took a little longer as it was not as easy as it first seemed, but now our packages can be used on all Unipi controllers with Debian 11.
                      We are now working on Bullseye OS images that we will release in the coming months. OS images will not be released immediately because we are working on a new unified approach to information about the controller and its peripherals.
                      For Unipi Neuron and Unipi 1.1 it is now possible to use the RaspberryPi OS image.
                      Antonin
                      A 1 Reply Last reply
                      Reply Quote 1
                        acecile @AVsetula
                        @AVsetula is it possible to get an early access to the debian 11 image ? Just got a set of 25 neurons and I'd rather use debian 11 even if it is still beta.
                        • K
                          knebb @acecile
                          Hi all,
                          anyone having a hint how to upgrade now to Debian 11? I do not want to risk my installation here....
                          For Debian/ Raspbian I will have to replace "buster" with "bullseye", right?
                          /etc/apt/sources.list.d/raspi.list:
                          deb http://archive.raspberrypi.org/debian/ buster main ui
                          Additionally I need to do the same here, correct?
                          /etc/apt/sources.list.d/unipi.list:
                          deb https://repo.unipi.technology/debian buster main
                          Once edited, run apt update; apt full-upgrade; apt autoremove based on this tutorial.
                          Is this the way to go?
                          Greetings
                          /KNEBB
                          • K
                            knebb @knebb
                            I did as shown above. Ended in an Neuron M103 not booting :(
                            Unfortunately I do not have a possibility to attach a screen to M103 (or can I use the HDMI of the inner Raspi?)
                            I ended up in restoring the previous image.
                            So I can not even tell what the issue was- I guess some kernel/ grub based issues.
                            At current stage I would recommend against the above upgrade procedure.
                            /KNEBB
                            • K
                              kepi @knebb
                              @knebb, I have been successful with my Axon device couple months ago.
                              Here is my /etc/apt/sources.list.d/unipi.list:
                              deb https://repo.unipi.technology/debian bullseye main
                              These are the steps I followed:
                              sudo apt update
                              sudo apt upgrade
                              sudo apt full-upgrade
                              I didn't remove any packages after full-upgrade and simply rebooted with a backup in place. After restart, I removed all obsolete packages but those which had unipi or axon in name (see later).
                              Currently, I'm still using the kernel from Buster because the kernel packages in Bullseye appear to be broken. If I understand correctly, we should be able to use unipi-kernel-modules-dkms with the normal Debian kernel. Unfortunately, it currently has broken dependencies, namely the unavailable unipi-kernel-headers and unipi-os-configurator-data.
                              Here is the list of obsolete Buster packages I have left on hold:
                              • unipi-kernel-modules
                              • unipi-common
                              • axon-kernel-headers
                              • axon-kernel-image
                              Since I don't currently need a new kernel, I'm not in a rush to resolve this. However, it would be great to receive an official update.
                              • G gabrielsoudry referenced this topic on
                              • G
                                gabrielsoudry
                                Hello @knebb
                                Any news about the upgrade? An ETA maybe ?
                                Z 1 Reply Last reply
                                • Z
                                  zdenek_rusek @gabrielsoudry
                                  @gabrielsoudry Hello Gabriel,
                                  We plan to release the new Bookworm-compatible EVOK, along with new OS images, by the end of February. However, if we encounter bugs during testing, this may extend until the end of March.
                                  ZR
                                  tag @martin_triska
                                  Reply Quote 1
