    EVOK shows no I/O - Neuron L513
    • N
      Negropo last edited by
      I bought an unused Neuron L513 (Serial-Number: 1) and I want now to test the EVOK control panel. I started with a fresh Pi OS "Buster" and installed the EVOK like it shown in the documentation. But when I start the web frontend the control panel shows only the "Analog Input 1.01" - no further entries on in- or output. Them same at system.
      EVOK service ist running. What did I wrong?
      Negropo
        marioverhaeg last edited by
        Hi Negropo,
        Can you enable debug logging in the /etc/evok.conf and check the /var/log/evok.log file after restarting the service? Even though you're on a totally different platform, this looks like a similar problem as what I ran into yesterday as well: https://forum.unipi.technology/topic/1124/unipi-1-1-raspberry-pi-4-buster-evok-node-red
        Kind regards,
        Mario
        • N
          Hello @marioverhaeg,
          here ist my evok.log with debug=on. Evertything seems fine, but it still won't work. I only see Analog Input & Output from 1.01.
          I also made a snapshot from my evok.conf
          And as I saw it on your post made an output from dpkg -l | egrep "raspberrypi|evok|unipi|python"
          Output dpkg
          Maybe @Martin-Kudláček could help me too?
          Kind regards
          Negropo
            martin_triska last edited by
            sorry for the very late reply. Have you already solved the issue? If so, can you please share the solution?
            Thank you so much!
            N 1 Reply Last reply Reply Quote 0
            • N
              Negropo @martin_triska last edited by
              Hello @martin_triska,
              unfortunately my problem isn't solved. I think there is an programming error or a hardware malfunction. Everytime I try an http://ip-neuron/rest/all I get an error "SyntaxError: JSON.parse: unexpected character at line 1 column 5827 of the JSON data".
              I use the FHEM module for Neuron and can add manually the devices. After adding a relay in FHEM an switch them. The relay is also shown in the EVOK Control Panel. Saving the current state in flash isn't working too. When I restart/reboot the Neuron all manual added inputs, outputs etc. are gone and I just see only AI 1_01 and AO 1_01 like in my first post.
              I also tried to communicate via Modbus. It worked as long as I didn't restart/reboot the Neuron. Afterwards I have the same behaviour like described above.
              I use the latest Neuron-OS-Image from 21.12.2021. The installing process of OS and EVOK was without any error.
              For now I can't use my Neuron because it's to unsafe for loosing all devices after a reboot oder repower.
              Maybe this further information may help you to give me an advice.
              Thank you and a I wish you a happy new year!
              Kind regards
              Norman
              • N
                Negropo @Negropo last edited by
                In the event monitor of FHEM I can see also the following message when I make a "get all": "2022.01.02 14:17:08 3: Neuron (NeuronL513) error decoding response: malformed JSON string, neither tag, array, object, number, string or atom, at character offset 5830 (before "NaN, "circuit": "3_0...") at ./FHEM/00_Neuron.pm line 424." As I can see the error occurs on AI 3_01 or an other till AI 3_04.
