Bugs In Latest Axons
Hi everyone. I have just restored an image that I made some months ago using your backup tool. I have made many different axons starting from this USB backup but the new one arrived seems to have some problems. After I restore the backup from the usb the filesystem is not resized and is stucked at 100% use so I cannot do anything.
How can I fix this?
Filesystem Size Used Avail Use% Mounted on udev 450M 0 450M 0% /dev tmpfs 100M 2.9M 97M 3% /run /dev/disk/by-path/platform-1c11000.mmc-part2 1.4G 1.3G 476K 100% / tmpfs 498M 0 498M 0% /dev/shm tmpfs 5.0M 0 5.0M 0% /run/lock tmpfs 498M 0 498M 0% /sys/fs/cgroup tmpfs 150M 2.0M 149M 2% /tmp tmpfs 50M 0 50M 0% /tftpboot /dev/mmcblk0p1 100M 55M 46M 55% /boot tmpfs 100M 0 100M 0% /run/user/1000Also when I try to run a firmware update I get:
unipi@S105-sn470:~$ /opt/unipi/tools/fwspi -i 0 Unable to create the arm[0] context unipi@S105-sn470:~$ /opt/unipi/tools/fwspi -v --auto ARMINIT: Cannot open device /dev/unipispi ARMINIT: Cannot open device /dev/unipispi ARMINIT: Cannot open device /dev/unipispi Firmware autoupdate finished unipi@S105-sn470:~$Also I'm not able to start the axon in Service Web Interface mode (by keep pressing the button while starting). It remains stucked. This also happens with all other axons so the problem is not caused by the restore process but affetcts all axons
Other info:
unipi@S105-sn470:~$ sudo fdisk -l Disk /dev/mmcblk0: 7.3 GiB, 7818182656 bytes, 15269888 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x92824060 Device Boot Start End Sectors Size Id Type /dev/mmcblk0p1 49152 253951 204800 100M 83 Linux /dev/mmcblk0p2 253952 3098623 2844672 1.4G 83 Linux /dev/mmcblk0p3 3098624 15269887 12171264 5.8G 83 Linux Disk /dev/mmcblk0boot1: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disk /dev/mmcblk0boot0: 4 MiB, 4194304 bytes, 8192 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes unipi@S105-sn470:~$ -
Actually what I have done is:
sudo /sbin/fdisk /dev/mmcblk0 Welcome to fdisk (util-linux 2.29.2). Changes will remain in memory only, until you decide to write them. Be careful before using the write command. Command (m for help): p Disk /dev/mmcblk0: 7.3 GiB, 7818182656 bytes, 15269888 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x92824060 Device Boot Start End Sectors Size Id Type /dev/mmcblk0p1 49152 253951 204800 100M 83 Linux /dev/mmcblk0p2 253952 3098623 2844672 1.4G 83 Linux /dev/mmcblk0p3 3098624 15269887 12171264 5.8G 83 Linux Command (m for help): d Partition number (1-3, default 3): 3 Partition 3 has been deleted. Command (m for help): d Partition number (1,2, default 2): 2 Partition 2 has been deleted. Command (m for help): n Partition type p primary (1 primary, 0 extended, 3 free) e extended (container for logical partitions) Select (default p): 1 Value out of range. p primary (1 primary, 0 extended, 3 free) e extended (container for logical partitions) Select (default p): p Partition number (2-4, default 2): 2 First sector (2048-15269887, default 2048): 253952 Last sector, +sectors or +size{K,M,G,T,P} (253952-15269887, default 15269887): 15269887 Created a new partition 2 of type 'Linux' and of size 7.2 GiB. Partition #2 contains a ext4 signature. Do you want to remove the signature? [Y]es/[N]o: N Command (m for help): p Disk /dev/mmcblk0: 7.3 GiB, 7818182656 bytes, 15269888 sectors Units: sectors of 1 * 512 = 512 bytes Sector size (logical/physical): 512 bytes / 512 bytes I/O size (minimum/optimal): 512 bytes / 512 bytes Disklabel type: dos Disk identifier: 0x92824060 Device Boot Start End Sectors Size Id Type /dev/mmcblk0p1 49152 253951 204800 100M 83 Linux /dev/mmcblk0p2 253952 15269887 15015936 7.2G 83 Linux Command (m for help): w The partition table has been altered. Calling ioctl() to re-read partition table. Re-reading the partition table failed.: Device or resource busy The kernel still uses the old table. The new table will be used at the next reboot or after you run partprobe(8) or kpartx(8). unipi@S105-sn470:~$ sudo rebootReboot then:
unipi@S105-sn470:~$ sudo /sbin/resize2fs /dev/mmcblk0p2 resize2fs 1.43.4 (31-Jan-2017) Filesystem at /dev/mmcblk0p2 is mounted on /; on-line resizing required old_desc_blocks = 1, new_desc_blocks = 1 The filesystem on /dev/mmcblk0p2 is now 1876992 (4k) blocks long.Now the partition seems to be ok but some thing aren't working as expected.
Hi @roberts_lando,
the backup2usb tool has some serious flaws, as we discovered last week and we took it down from downloads section. We do not recommend to use it at all. There are couple of things we need to fix first to make it available again.Best regards,
@Martin-Kudláček I'm using a customized image of the axon, that was my only way to backup/restore multiple devices in a quick way. How can I do it now?
I really need this or for me it's almost impossible to work with them. I have spent two days tring to figure out what's happened. I have then created a "restore usb" using this image: https://kb.unipi.technology/en:files:software:os-images:00-start?redirect=1#axon_opensource_os
Starting from that I have installed all the software needed and created a backup of that but I'm not able to restore it anyway in other axons.
Also there is a bug in all latest models I have received as no one is able to go in service mode, the run led keeps blink every second and the raws leds never switch on. In able to restore that I have to reset them using the image I previously linked here.
I will do a refund of all axons I bought If I can't find a fix of this
If anyone got this issue the main problem was caused by the wrong partition table on some new Axons units.
In order to be able to restore your backups you have to:
- Flash a valid image like https://kb.unipi.technology/en:files:software:os-images:00-start?redirect=1#axon_opensource_os
- Connect using ssh to the Axon and follow the steps on my previous comment to resize the partitions correctly (remember, once you fix the partition table to reboot and use the
resize2fscommand to expand the filesystem - Shutdown your axon and restore the backup
@Martin-Kudláček I hope that next Axons units will have this bug fixed as it becomes very difficult (and time loss) for me do all this steps in multiple axons
Hello @roberts_lando,
the fix is currently in the making.Best regards,
Hello, @roberts_lando. I have a serie of Axon dispatched accross Europe.
All the controllers that had been setup around april 2020 using the backup2usb tool have the problem of the Filesystem size. There are about 25 of them.
Is the manipulation "safe" to run? Or I might/will loose datas ?
The controllers are running a nodeJS application that's doing some logic and sending the datas to our server. There is no 'critical' data on the controller expect the nodeJS piece of code + dependencies.All the controllers are behind a IPSec and the setup don't allow access to internet so if we have to set them up again it would be difficult. I 'just'
have SSH control -
@PhilesG The steps (if done correctly) only resize the partition so no data is lost. BTW is something goes wrong it could. I know @Martin-Kudláček also proposed me to create a script to automatically fix the partition problem, I think that would be the safer way
