    unipi-kernel-modules-dkms does not generate modules on upgrade
    16 Posts 5 Posters 4.9k Views 1 Watching
      Achilleas Kotsis @Martin Kudláček
      Hi @martin-kudláček,
      thanks for the reward.
      Can't find the testing repository url, can you please send it?
      Achilleas
        Martin Kudláček @Achilleas Kotsis
        Hi @achilleas-kotsis,
        the change has been merged to the 1.2.18.
        The testing repository has the same url, just make sure to add component test:
        deb https://repo.unipi.technology/debian buster main test
        To prefer packages from main, add file /etc/apt/preferences.d/10-unipi-prefer-main with this content:
        Package: *
        Pin: release o=unipi,c=main
        Pin-Priority: 900
        All of that is preconfigured in our images.
          Achilleas Kotsis
          One more patch against the latest version that renames the old file during package configuration, because if it gets upgraded on a live system, the previously inserted code is not executed (script exits early if devices are found)
          --- setbootconfig.sh.orig	2019-12-19 21:39:51.490185707 +0200
          +++ setbootconfig.sh	2019-12-19 22:04:27.094799784 +0200
          @@ -9,6 +9,10 @@
           if [ "$1" = "--noreboot" -o -n "${DESTDIR}" ]; then
               ## called from package install
               MNTDIR=/boot
          +    # Move old file using '-' instead of '_'
          +    [ -f "${MNTDIR}/config-unipi.inc" ] && mv -f "${MNTDIR}/config-unipi.inc" "${MNTDIR}/config_unipi.inc"
          +    # Change include using '-' instead of '_'
          +    sed -i "s/include config-unipi\.inc/include config_unipi.inc/" "${MNTDIR}/config.txt"
               # check if running from "real" Neuron system
               grep -q '^/dev/mmcblk[[:digit:]]p1 /boot ' /proc/mounts && IS_REAL_SYSTEM=1
           else
          This cleaned up my system perfectly doing a dpkg-reconfigure unipi-common so I suppose it should be working on the package being upgraded also. I can test one of my systems if you generate a testing package to see if it applies cleanly.
            thank you for the testing. Your patch is included in the testing version 1.2.19.test.20191220083937 available in the testing repository.
            A 1 Reply Last reply
              @martin-kudláček said in unipi-kernel-modules-dkms does not generate modules on upgrade:
              I can confirm the package works as intended on my systems.
              Achilleas
                Achilleas Kotsis
                Hi @Martin-Kudláček,
                found another issue on latest rpi kernel.
                Building initial module for 4.19.93+
                Error!  Build of unipi.ko failed for: 4.19.93+ (armv7l)
                Consult the make.log in the build directory
                /var/lib/dkms/unipi/1.36/build/ for more information.
                root@vkplc-home:~# cat /var/lib/dkms/unipi/1.36/build/make.log
                DKMS make.log for unipi-1.36 for kernel 4.19.93+ (armv7l)
                Wed 22 Jan 2020 12:33:22 PM EET
                make: Entering directory '/usr/src/linux-headers-4.19.93+'
                  CC [M]  /var/lib/dkms/unipi/1.36/build/unipi/src/unipi_spi.o
                  CC [M]  /var/lib/dkms/unipi/1.36/build/unipi/src/unipi_iio.o
                  CC [M]  /var/lib/dkms/unipi/1.36/build/unipi/src/unipi_gpio.o
                  CC [M]  /var/lib/dkms/unipi/1.36/build/unipi/src/unipi_uart.o
                /var/lib/dkms/unipi/1.36/build/unipi/src/unipi_uart.c: In function ‘neuronspi_uart_handle_rx’:
                /var/lib/dkms/unipi/1.36/build/unipi/src/unipi_uart.c:320:31: error: passing argument 1 of ‘uart_handle_sysrq_char’ from incompatible pointer type [-Werror=incompatible-pointer-types]
                    if (uart_handle_sysrq_char(port, ch))
                In file included from /var/lib/dkms/unipi/1.36/build/unipi/src/unipi_common.h:36,
                                 from /var/lib/dkms/unipi/1.36/build/unipi/src/unipi_uart.h:22,
                                 from /var/lib/dkms/unipi/1.36/build/unipi/src/unipi_uart.c:19:
                ./include/linux/serial_core.h:514:42: note: expected ‘struct uart_port *’ but argument is of type ‘struct neuronspi_port *’
                 uart_handle_sysrq_char(struct uart_port *port, unsigned int ch) { return 0; }
                  CC [M]  /var/lib/dkms/unipi/1.36/build/unipi/src/unipi_sysfs.o
                cc1: some warnings being treated as errors
                make[1]: *** [scripts/Makefile.build:303: /var/lib/dkms/unipi/1.36/build/unipi/src/unipi_uart.o] Error 1
                make[1]: *** Waiting for unfinished jobs....
                make: *** [Makefile:1522: _module_/var/lib/dkms/unipi/1.36/build/unipi] Error 2
                make: Leaving directory '/usr/src/linux-headers-4.19.93+'
                  CC [M]  /var/lib/dkms/unipi/1.36/build/rtc-unipi/rtc-unipi.o
                /var/lib/dkms/unipi/1.36/build/rtc-unipi/rtc-unipi.c: In function ‘rtc_unipi_probe’:
                /var/lib/dkms/unipi/1.36/build/rtc-unipi/rtc-unipi.c:666:6: warning: ISO C90 forbids mixed declarations and code [-Wdeclaration-after-statement]
                      struct nvmem_config nvmem_cfg = {
                  Building modules, stage 2.
                  MODPOST 1 modules
                  CC      /var/lib/dkms/unipi/1.36/build/rtc-unipi/rtc-unipi.mod.o
                  LD [M]  /var/lib/dkms/unipi/1.36/build/rtc-unipi/rtc-unipi.ko
                make: Leaving directory '/usr/src/linux-headers-4.19.93+'```
                Line 320 in unipi_uart.c
                passes "port" as an arqument to uart_handle_sysrq_char, which is of type "struct neuronspi_port", but uart_handle_sysrq_char expects a type of "struct uart_port", which is part of struct neuronspi_port as seen on unipi_common.h.
                Changing line 320 as below seems to fix the issue.
                if (uart_handle_sysrq_char(&port->port, ch))
                Martin KudláčekM P 2 Replies Last reply
                  thanks again for the fix:) We have merged it into a testing repository alongside with fix of the Makefile, which masked this error to the Gitlab CI and allowed building it in the first place. We will test it and soon merge into the master branch.
                    pmandeli @Achilleas Kotsis
                    Hi @achilleas-kotsis , @Martin-Kudláček ,
                    has it been fixed in the master branch? I am facing to the same problem.
                    Thank you
                      Martin Kudláček @pmandeli
                      Hi @pmandeli,
                      not yet, but the change is available for testing here: https://repo.unipi.technology/debian/pool/test/u/unipi-kernel-modules/unipi-kernel-modules-dkms_1.37.test.20200122161658_all.deb
                      • wbm smartW
                        wbm smart
                        Thank you
