Hydraulic Press project on Neuron M203 - beginner needs help
@josar Yes, we have a lot of leaking problems at the moment, but its almost finished. Still trying to figure out something more basic for HMI than a weintek panel. I will post the updates with some pictures soon, gonna take about 2 weeks I hope.
So we got most of the leaking solved, time came to code the auto cycle.
While coding manal valve closing/openings on button presses was easy, this is where i began to struggle.
I followed a guide which was based on a TwinCat 3, but obviously things are different between IDE's.
What i would like to know is to how to properly init and call a simple timer and r_trig function block in mervis. Does it have to be manually added into the main.fbd, then called properly from main.st for example? Or can i just declare it in .st which would seem more convenient for me.VAR // timers fbStartautotimer:TON; // triggers fbAutoInit_RTRIG:R_TRIG; fbAutoOff_RTRIG:R_TRIG; fbCycle_RTRIG:R_TRIG; fbZeropos_RTRIG:R_TRIG; END_VARAlso im not sure if the code below will work even if I call the function blocks properly.
// auto cycle // button mapping hw.$Neuron M203_DI2.10$:= bManualMode; hw.$Neuron M203_DI2.11$:= bAutoMode; hw.$Neuron M203_DI2.12$:= bAutoEjectorMode; // pressure setpoint and scaling iPressure:= REAL_TO_INT(hw.$Neuron M203_AI1.01$); iPressure_setpoint:= 200; fbAutoInit_RTRIG(clk:=bAutoCycleOn); fbAutoOff_RTRIG(clk:=bAutoCycleOff); IF bAutoMode & fbAutoInit_RTRIG.Q AND NOT fbAutoOff_RTRIG.Q THEN bPumpOn:= TRUE; iState:= 10; ELSE bPumpOff:= TRUE; iState:= 0; END_IF; CASE iState OF 10: // timer init to let the pump run well fbStartautotimer(IN:bPumpOn,PT:T#2s); IF fbStartautotimer.Q THEN fbStartautotimer(IN:=FALSE); END_IF; fbCycle_RTRIG(clk:=fbStartautotimer.Q); IF fbCycletrigger_RTRIG.Q THEN iState:= 20; sCurrentCycleState:= "Pressing cycle start"; END_IF; 20: IF iPressure <= iPressure_setpoint AND NOT bLimitswitch2 & fbAutoOff_RTRIG.Q THEN bTableDown_valve:= TRUE; sCurrentCycleState:= "Pressing to the pressure setpoint"; iState:= 30; ELSE bTableDown_valve:= FALSE; sCurrentCycleState:= "Cycle stopped, reset"; END_IF; 30: // expression cycle completed, move the table upwards to 0 position fbZeropos_RTRIG(clk:=iState:=30); IF fbZeropos_RTRIG.Q AND NOT bLimitswitch3 & fbAutoOff_RTRIG.Q THEN bTableUp_valve:= TRUE; iTotalAutoCycles:= iTotalAutoCycles +1; sCurrentCycleState:= "Zeroing table, cycle end"; END_IF; END_CASE;I would appreciate a helping hand on this one.
Also wondering if this: https://www.waveshare.com/wiki/3.5inch_HDMI_LCD
can be hooked up to display the pressure? And assign some leftover DI's for +/- ?
If you want to call a function(or FB) in a ST, you can create aditional program in ST and call the FB from there.
The display however is a HDMI and cannot be hooked to any DIs.
I guess that @r3sist was trying to cover two separate topics:
- using the 3.5" screen as local HMI (or operator screen, depending on the preferred terminology)
- using DIs to manipulate some variable(s) in the algorithm, e.g. maximum and minimum for pressure
Am I right?
Jaroslav
@jaroslav_sobota
Yes exactly. I just need anything to notify the operator directly on the machine about current pressure , and let him adjust this one pressure setpoint variable. It could even be a segment lcd. -
@r3sist thanks for clarification.
The best would be to setup a HMI terminal like this one https://www.unipi.technology/weintek-mt8051ip-p198?categoryId=29
Hooking buttons to DIs would be OK, but you would have to figure out the display since Neuron do not have native support for HDMI or I2C displays.
@r3sist said in Hydraulic Press project on Neuron M203 - beginner needs help:
If segment LCD is all you need, maybe something like this could do the trick:
https://en.papouch.com/tds-rs485-7-segment-led-display-p1922/You can connect it via RS485 and communicate using Modbus RTU.
@jaroslav_sobota said in Hydraulic Press project on Neuron M203 - beginner needs help:
Oh, thanks, I was totally unaware of displays over RS485. Yes, this should work.
Going to look for a suitable device then, and post updates here. -
I finally convinced my boss, and we went with Weintek MT8051iP.
Unfortunately i am not able to make any progress with automatic work cycle other than getting function blocks to work at last. Although nothing happens when i press fbAutoCycleOn.Also i wanted to make things easier for me and tried to rename generated variable names for Neuron I/O, but i think the way I did it is completely wrong as I've ran into random troubles.
At first i tried something like this :hw.$Neuron M203_RO_2.01_w$:= bPumpOn;But it didnt work, neither for RO or DI's.
iPressure:= REAL_TO_INT(hw.$Neuron M203_AI_1.01$); iPressure_setpoint:=200; IF iPressure >= iPressure_setpoint THEN xPressureReached:= TRUE; ELSE xPressureReached:= FALSE; END_IF;(*// relay outputs binding // down valve IF bTableDown_valve THEN hw.$Neuron M203_RO_2.01_w$:= TRUE; ELSE hw.$Neuron M203_RO_2.01_w$:= FALSE; END_IF; // up valve IF bTableUp_valve THEN hw.$Neuron M203_RO_2.02_w$:= TRUE; ELSE hw.$Neuron M203_RO_2.02_w$:= FALSE; END_IF; // bot down valve IF bBottomTableDown_valve THEN hw.$Neuron M203_RO_2.03_w$:= TRUE; ELSE hw.$Neuron M203_RO_2.03_w$:= FALSE; END_IF; // bot up valve IF bBottomTableUp_valve THEN hw.$Neuron M203_RO_2.04_w$:= TRUE; ELSE hw.$Neuron M203_RO_2.04_w$:= FALSE; END_IF; // high pressure IF bHighPressure_valve THEN hw.$Neuron M203_RO_2.05_w$:= TRUE; ELSE hw.$Neuron M203_RO_2.05_w$:= FALSE; END_IF; // pump IF bPumpOn THEN hw.$Neuron M203_RO_2.06_w$:= TRUE; ELSE hw.$Neuron M203_RO_2.06_w$:= FALSE; END_IF; // input assignment // manual IF hw.$Neuron M203_DI_2.10$ THEN bManualMode:= TRUE; ELSE bManualMode:= FALSE; END_IF; // auto IF hw.$Neuron M203_DI_2.11$ THEN bAutoMode:= TRUE; ELSE bAutoMode:= FALSE; END_IF; // autoeject IF hw.$Neuron M203_DI_2.12$ THEN bAutoEjectorMode:= TRUE; ELSE bAutoEjectorMode:= FALSE; END_IF; // Limit up IF hw.$Neuron M203_DI_1.01$ THEN bLimitTableZero:= TRUE; ELSE bLimitTableZero:= FALSE; END_IF; // Limit bot up IF hw.$Neuron M203_DI_1.02$ THEN bLimitBottomTableUp:= TRUE; ELSE bLimitBottomTableUp:= FALSE; END_IF; // Limit bot down IF hw.$Neuron M203_DI_1.03$ THEN bLimitBottomTableDown:= TRUE; ELSE bLimitBottomTableDown:= FALSE; END_IF; // Pump on IF hw.$Neuron M203_DI_2.01$ THEN bPumpOn_button:= TRUE; ELSE bPumpOn_button:= FALSE; END_IF; // Pump off IF hw.$Neuron M203_DI_2.02$ THEN bPumpOff_button:= TRUE; ELSE bPumpOff_button:= FALSE; END_IF; // Table down IF hw.$Neuron M203_DI_2.03$ THEN bTableDown_button:= TRUE; ELSE bTableDown_button:= FALSE; bTableDown_valve:= FALSE; END_IF; // Table up IF hw.$Neuron M203_DI_2.04$ THEN bTableUp_button:= TRUE; ELSE bTableUp_button:= FALSE; bTableUp_valve:= FALSE; END_IF; // Bot table up IF hw.$Neuron M203_DI_2.05$ THEN bBottomTableUp_button:= TRUE; ELSE bBottomTableUp_button:= FALSE; END_IF; // Bot table down IF hw.$Neuron M203_DI_2.06$ THEN bBottomTableDown_button:= TRUE; ELSE bBottomTableDown_button:= FALSE; END_IF; // Auto on IF hw.$Neuron M203_DI_2.07$ THEN bAutoCycleOn:= TRUE; ELSE bAutoCycleOn:= FALSE; END_IF; // Auto off IF hw.$Neuron M203_DI_2.08$ THEN bAutoCycleOff:= TRUE; ELSE bAutoCycleOff:= FALSE; END_IF; // Zero IF hw.$Neuron M203_DI_2.09$ THEN bZeroTable_button:= TRUE; ELSE bZeroTable_button:= FALSE; END_IF;So right after this I have these IF's :
// table up IF bTableUp_button = TRUE AND NOT bLimitTableZero THEN bTableUp_valve:=TRUE; ELSE bTableUp_valve:=FALSE; END_IF; // table down IF bTableDown_button = TRUE AND NOT xPressureReached THEN bTableDown_valve:=TRUE; ELSE bTableDown_valve:=FALSE; END_IF; // ejector down IF bBottomTableDown_button = TRUE & bLimitBottomTableDown = FALSE & bManualMode = TRUE THEN bBottomTableDown_valve:=TRUE; ELSE bBottomTableDown_valve:= FALSE; END_IF; // ejector up IF bBottomTableUp_button = TRUE & bLimitBottomTableUp = FALSE & bManualMode = TRUE THEN bBottomTableUp_valve:=TRUE; ELSE bBottomTableUp_valve:=FALSE; END_IF;///
fbAutoInit_RTRIG(CLK:=bAutoCycleOn); fbAutoOff_RTRIG(CLK:=bAutoCycleOff); IF fbAutoInit_RTRIG.Q THEN xPumpStart:= TRUE; iState:= 10; ELSE xPumpStart:= FALSE; END_IF; CASE iState OF 10: // timer init to let the pump run well fbStartautotimer(IN:=xPumpStart,PT:=iPumpTimeDelay); IF fbStartautotimer.Q THEN fbStartautotimer(IN:=FALSE); END_IF; fbCycle_RTRIG(clk:=fbStartautotimer.Q); IF fbCycle_RTRIG.Q THEN sCurrentCycleState:= "Pressing cycle start"; END_IF; IF bLimitTableZero = FALSE THEN bTableUp_valve:= TRUE; END_IF; iState:= 20; 20: IF iPressure <= iPressure_setpoint AND NOT fbAutoOff_RTRIG.Q AND bLimitBottomTableDown THEN bTableDown_valve:= TRUE; sCurrentCycleState:= "Pressing to the pressure setpoint"; xAutoZeroPos:= TRUE; ELSE bTableDown_valve:= FALSE; sCurrentCycleState:= "Cycle stopped, reset"; END_IF; iState:= 30; 30: // expression cycle completed, move the table upwards to 0 position fbZeropos_RTRIG(clk:=xAutoZeroPos); IF fbZeropos_RTRIG.Q AND NOT bLimitTableZero & fbAutoOff_RTRIG.Q THEN bTableUp_valve:= TRUE; iTotalAutoCycles:= iTotalAutoCycles +1; sCurrentCycleState:= "Zeroing table, cycle end"; END_IF; END_CASE;And im totally clueless about what's wrong. I also should point out that i have all that code in one main .st file. Should i divide functions for manual operation and automatic cycle into another .st? Set individual tasks for them?
Any help or tips on this would be very appreciated. Im basically out of ideas and my knowledge on PLC programming is narrow.
Oh of course Mervis shows no errors. I can upload the project if someone is willing to take a look.
Hi @r3sist,
the:IF bPumpOn THEN hw.$Neuron M203_RO_2.06_w$:= TRUE; ELSE hw.$Neuron M203_RO_2.06_w$:= FALSE; END_IF;is exactly the same as this:
hw.$Neuron M203_RO_2.06_w$:= bPumpOn;If there is no syntactic error, which would be detected upon MervisIDE Build, then there is error in the program itself. Try uploading it here or sending it to [email protected]. Please, include a VERY detailed description of the real process, not the itself program. It will help find the real issue.
