    Error adding controller to Mervis IDE (HW capabilities)
    Scheduled Pinned Locked Moved Axon series
    1 Posts 1 Posters 1.3k Views
      Mynca_2000
      I can add my Axon M205 in the Mervis IDE until I activated the wi-fi on this device.
      From then on if I want to add this device, the mervis IDE will find it through an udp broadcast, but when I select it there is a problem when downloading the hw capabilities.
      The error I'm getting is the following: Failed to connect to PLC. Probably incorrect IP settings.
      I can only assume this has something to do with the wi-fi settings because this was the last thing I did, and from then it started to fail. I also can't reach the update web module altough it's booted in service mode.
      Any thoughts?
      Kr,
      Mynca
