    Shutdown process / status display.
    Scheduled Pinned Locked Moved Axon series
    2 Posts 2 Posters 1.3k Views 1 Watching
      BeerGeek
      I want to display the "Off" status on Axon. When we switch OS to shutdown mode (shutdown -h now), I want to turn on the green LED when the user can switch power off. So I will avoid violating the flash card and the os file system.
      Can't find a solution, maybe there are some standard solutions?
        Martin Kudláček @BeerGeek
        Hi @beergeek,
        there is probably a number of ways how to do it. This could be one of them:
        • create /usr/local/sbin/shutdown and add the exec bit to it
        • in the script, specify the logic - get the IOs into safe state and/or light up the user LEDs
        • at the end of the script, call shutdown -h now
        The logic can use the SysFS approach such as this:
        echo 1 > /run/unipi/io_group1/do_1_01/do_value # sets DO1.1 to true
        Although you don't have the user LEDs available in the SysFS right now. For that, you can use mbpoll and set it via ModbusTCP.
