Attach PLC over VPN failed
Hi all,
i installed AXON in exchange station and now i need change PLC program. But i cannot connect PLC and when i start deploy solution, it write that PLC is only partially connected.How can connect the PLC without going to external place?
Hi @derinex,
to attach to the PLC via IP and port is a bit confusing.First, attach manually by filling the IP, port and the model of the PLC
Then proceed with attaching via "Use deploy parameters"After that, you should have the PLC fully attached.
Thanks Tomas,
its slightly confusing, but it works. In Deploy i must switch to Range instead of broadcast.Petr
