    How to set CONTROLLERTYPE to heating
    2 Posts 2 Posters 1.7k Views
      arolli
      Hi Team,
      I'm developing an exec with ST.
      I declare a var as "lib.core.V1_0.B31_Reverse_On_Off_Control_Sequence".
      By default it is setted for cooling.
      I'm trying to set for heating.
      If I use like this:
      varname (CONTROLLERTYPE:=heating);
      during the build it return the error:
      "Error Executables Exe_Termo ..... can not find the object 'heating' in the current context"
      Can you explain how it work to set the CONTROLLERTYPE into ST?
      thanks
      Antonio
        Martin Kudláček @arolli
        Hello @arolli,
        this is described in the Mervis help files (F1). Look for "B31" and you will see that the input parameter is type "CONTROLLERTYPE" with a hint how to use it.
