    Humidity Sensors and UniPi 8 Port Hub
    Scheduled Pinned Locked Moved Other Peripherals
    2 Posts 2 Posters 1.5k Views 1 Watching
    • N
      nigel.skates
      Hi
      Can you have a mixture of Temperature and Humidity sensors on the same UniPi 8 port Hub?
      Can you recommend a pre-made Humidity sensor that will work with the UniPi pin outs?
        tomas_hora administrators @nigel.skates
        @nigel-skates since all are 1wire senosrs, then yes :) any of these sensors work except you have to make your own cable with the RJ45 connector in order to be used in the hub https://www.unipi.technology/digital-1-wire-c3
