    All ports disappear via webinterface after EVOK update on L203
    3880
    • W
      wizro_pl last edited by
      I use the image UniPian-Neuron-OS-2018-06-15.img on NEURON L203 (there already is correct file /etc/apt/sources.list.d/unipi.list and ngix)
      After I did an EVOK update according to
      https://github.com/UniPiTechnology/evok
      sudo su
      apt-get install unipi-modbus-tools
      apt-get install evok
      reboot
      and now, I don't see any ports via webbrowser as below
      How can I fix it?
        TomasKnot last edited by
        It looks like EVOK is not running. Please try using:
        sudo su
        systemctl status evok
        systemctl status unipitcp
        The output should at least say what's gone wrong. I will try to replicate it locally as well, but it may take a while.
        • W
          root@L203-sn18:/etc# systemctl status evok
          ● evok.service - EVOK ModBus/WebSocket/RPC Server
             Loaded: loaded (/lib/systemd/system/evok.service; enabled; vendor preset: enabled)
             Active: active (running) since Thu 2018-10-18 11:53:44 UTC; 56min ago
           Main PID: 509 (python)
             CGroup: /system.slice/evok.service
                     ├─509 /opt/evok/bin/python /opt/evok/lib/python2.7/site-packages/evok/evok.py
                     └─579 /opt/evok/bin/python /opt/evok/lib/python2.7/site-packages/evok/evok.py
          Oct 18 12:46:56 L203-sn18 OWFS[579]: DEFAULT: ow_reconnect.c:(72) DS2482-100 bus master reconnected
          Oct 18 12:47:16 L203-sn18 OWFS[579]: DEFAULT: ow_reconnect.c:(72) DS2482-100 bus master reconnected
          Oct 18 12:47:36 L203-sn18 OWFS[579]: DEFAULT: ow_reconnect.c:(72) DS2482-100 bus master reconnected
          Oct 18 12:47:56 L203-sn18 OWFS[579]: DEFAULT: ow_reconnect.c:(72) DS2482-100 bus master reconnected
          Oct 18 12:48:16 L203-sn18 OWFS[579]: DEFAULT: ow_reconnect.c:(72) DS2482-100 bus master reconnected
          Oct 18 12:48:36 L203-sn18 OWFS[579]: DEFAULT: ow_reconnect.c:(72) DS2482-100 bus master reconnected
          Oct 18 12:48:56 L203-sn18 OWFS[579]: DEFAULT: ow_reconnect.c:(72) DS2482-100 bus master reconnected
          Oct 18 12:49:16 L203-sn18 OWFS[579]: DEFAULT: ow_reconnect.c:(72) DS2482-100 bus master reconnected
          Oct 18 12:49:36 L203-sn18 OWFS[579]: DEFAULT: ow_reconnect.c:(72) DS2482-100 bus master reconnected
          Oct 18 12:49:56 L203-sn18 OWFS[579]: DEFAULT: ow_reconnect.c:(72) DS2482-100 bus master reconnected
          root@L203-sn18:/etc# systemctl status unipitcp
          ● unipitcp.service - Unipi Neuron/Axon Modbus/Tcp Server
             Loaded: loaded (/lib/systemd/system/unipitcp.service; enabled; vendor preset: enabled)
           Main PID: 538 (unipi_tcp_serve)
             CGroup: /system.slice/unipitcp.service
                     └─538 /opt/unipi-bin/unipi_tcp_server -p 502
          Oct 18 11:53:44 unipi systemd[1]: Starting Unipi Neuron/Axon Modbus/Tcp Server...
          Oct 18 11:53:44 unipi systemd[1]: Started Unipi Neuron/Axon Modbus/Tcp Server.
          • W
            hi, any updates?
              tomas_hora administrators @wizro_pl last edited by
              @wizro_pl Was it installed on a clean Raspbian? It might not work if evok was previously installed not using the package system.
              Can you also paste the output of dmesg and sytemctl status unipitcp?
              • W
                As I mentioned above I've used prepared by UniPi image of rasbian with evok embedded called "UniPian-Neuron-OS-2018-06-15.img". Reason, why I tried to do upgrade, was that this version didn't work correctly with api commands showed on your documentation, I couldn't control relays. I found in a thread on the forum that was a BUG which was fixed after the image release date.
                (of course before reinstall evok i did apt-get update; apt-get upgrade)
                dmesg:
                pi@L203-sn18:~ $ dmesg
                [    0.000000] Booting Linux on physical CPU 0x0
                [    0.000000] Linux version 4.14.34-v7+ (dc4@dc4-XPS13-9333) (gcc version 4.9.3        (crosstool-NG crosstool-ng-1.22.0-88-g8460611)) #1110 SMP Mon Apr 16 15:18:51 B        ST 2018
                [    0.000000] CPU: ARMv7 Processor [410fd034] revision 4 (ARMv7), cr=10c5383d
                [    0.000000] CPU: div instructions available: patching division code
                [    0.000000] CPU: PIPT / VIPT nonaliasing data cache, VIPT aliasing instructio        n cache
                [    0.000000] OF: fdt: Machine model: Raspberry Pi 3 Model B Rev 1.2
                [    0.000000] Memory policy: Data cache writealloc
                [    0.000000] cma: Reserved 8 MiB at 0x3ac00000
                [    0.000000] On node 0 totalpages: 242688
                [    0.000000] free_area_init_node: node 0, pgdat 80c84e40, node_mem_map ba3a100        0
                [    0.000000]   Normal zone: 2133 pages used for memmap
                [    0.000000]   Normal zone: 0 pages reserved
                [    0.000000]   Normal zone: 242688 pages, LIFO batch:31
                [    0.000000] random: fast init done
                [    0.000000] percpu: Embedded 17 pages/cpu @ba349000 s38720 r8192 d22720 u6963        2
                [    0.000000] pcpu-alloc: s38720 r8192 d22720 u69632 alloc=17*4096
                [    0.000000] pcpu-alloc: [0] 0 [0] 1 [0] 2 [0] 3
                [    0.000000] Built 1 zonelists, mobility grouping on.  Total pages: 240555
                [    0.000000] Kernel command line: 8250.nr_uarts=0 bcm2708_fb.fbwidth=656 bcm27        08_fb.fbheight=416 bcm2708_fb.fbswap=1 vc_mem.mem_base=0x3ec00000 vc_mem.mem_siz        e=0x40000000  dwc_otg.lpm_enable=0 console=ttyS0,115200 console=tty1 root=PARTUU        ID=3a49222d-02 rootfstype=ext4 elevator=deadline fsck.repair=yes rootwait
                [    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
                [    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
                [    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
                [    0.000000] Memory: 936028K/970752K available (7168K kernel code, 575K rwdata        , 2072K rodata, 1024K init, 706K bss, 26532K reserved, 8192K cma-reserved)
                [    0.000000] Virtual kernel memory layout:
                                   vector  : 0xffff0000 - 0xffff1000   (   4 kB)
                                   fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
                                   vmalloc : 0xbb800000 - 0xff800000   (1088 MB)
                                   lowmem  : 0x80000000 - 0xbb400000   ( 948 MB)
                                   modules : 0x7f000000 - 0x80000000   (  16 MB)
                                     .text : 0x80008000 - 0x80800000   (8160 kB)
                                     .init : 0x80b00000 - 0x80c00000   (1024 kB)
                                     .data : 0x80c00000 - 0x80c8fd4c   ( 576 kB)
                                      .bss : 0x80c96f4c - 0x80d478b4   ( 707 kB)
                [    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=4, Nodes=1
                [    0.000000] ftrace: allocating 25231 entries in 74 pages
                [    0.000000] Hierarchical RCU implementation.
                [    0.000000] NR_IRQS: 16, nr_irqs: 16, preallocated irqs: 16
                [    0.000000] arch_timer: cp15 timer(s) running at 19.20MHz (phys).
                [    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles:        0x46d987e47, max_idle_ns: 440795202767 ns
                [    0.000007] sched_clock: 56 bits at 19MHz, resolution 52ns, wraps every 43980        46511078ns
                [    0.000023] Switching to timer-based delay loop, resolution 52ns
                [    0.000278] Console: colour dummy device 80x30
                [    0.000822] console [tty1] enabled
                [    0.000859] Calibrating delay loop (skipped), value calculated using timer fr        equency.. 38.40 BogoMIPS (lpj=192000)
                [    0.000899] pid_max: default: 32768 minimum: 301
                [    0.001227] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
                [    0.001260] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
                [    0.002213] Disabling memory control group subsystem
                [    0.002313] CPU: Testing write buffer coherency: ok
                [    0.002721] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
                [    0.003112] Setting up static identity map for 0x100000 - 0x10003c
                [    0.003246] Hierarchical SRCU implementation.
                [    0.003898] smp: Bringing up secondary CPUs ...
                [    0.004602] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
                [    0.005357] CPU2: thread -1, cpu 2, socket 0, mpidr 80000002
                [    0.006097] CPU3: thread -1, cpu 3, socket 0, mpidr 80000003
                [    0.006200] smp: Brought up 1 node, 4 CPUs
                [    0.006271] SMP: Total of 4 processors activated (153.60 BogoMIPS).
                [    0.006293] CPU: All CPU(s) started in HYP mode.
                [    0.006310] CPU: Virtualization extensions available.
                [    0.007179] devtmpfs: initialized
                [    0.018098] VFP support v0.3: implementor 41 architecture 3 part 40 variant 3        rev 4
                [    0.018348] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, ma        x_idle_ns: 19112604462750000 ns
                [    0.018392] futex hash table entries: 1024 (order: 4, 65536 bytes)
                [    0.018968] pinctrl core: initialized pinctrl subsystem
                [    0.019726] NET: Registered protocol family 16
                [    0.022347] DMA: preallocated 1024 KiB pool for atomic coherent allocations
                [    0.027038] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint        registers.
                [    0.027070] hw-breakpoint: maximum watchpoint size is 8 bytes.
                [    0.027294] Serial: AMBA PL011 UART driver
                [    0.028928] bcm2835-mbox 3f00b880.mailbox: mailbox enabled
                [    0.029403] uart-pl011 3f201000.serial: could not find pctldev for node /soc/        gpio@7e200000/uart0_pins, deferring probe
                [    0.060884] bcm2835-dma 3f007000.dma: DMA legacy API manager at bb813000, dma        chans=0x1
                [    0.062312] SCSI subsystem initialized
                [    0.062550] usbcore: registered new interface driver usbfs
                [    0.062619] usbcore: registered new interface driver hub
                [    0.062718] usbcore: registered new device driver usb
                [    0.070066] raspberrypi-firmware soc:firmware: Attached to firmware from 2018        -09-21 15:43
                [    0.071376] clocksource: Switched to clocksource arch_sys_counter
                [    0.148772] VFS: Disk quotas dquot_6.6.0
                [    0.148885] VFS: Dquot-cache hash table entries: 1024 (order 0, 4096 bytes)
                [    0.149091] FS-Cache: Loaded
                [    0.149299] CacheFiles: Loaded
                [    0.158121] NET: Registered protocol family 2
                [    0.158857] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
                [    0.158987] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
                [    0.159189] TCP: Hash tables configured (established 8192 bind 8192)
                [    0.159335] UDP hash table entries: 512 (order: 2, 16384 bytes)
                [    0.159396] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
                [    0.159642] NET: Registered protocol family 1
                [    0.160093] RPC: Registered named UNIX socket transport module.
                [    0.160118] RPC: Registered udp transport module.
                [    0.160137] RPC: Registered tcp transport module.
                [    0.160156] RPC: Registered tcp NFSv4.1 backchannel transport module.
                [    0.160368] Trying to unpack rootfs image as initramfs...
                [    0.519296] Freeing initrd memory: 4204K
                [    0.524723] hw perfevents: enabled with armv7_cortex_a7 PMU driver, 7 counter        s available
                [    0.527560] workingset: timestamp_bits=14 max_order=18 bucket_order=4
                [    0.535532] FS-Cache: Netfs 'nfs' registered for caching
                [    0.536156] NFS: Registering the id_resolver key type
                [    0.536208] Key type id_resolver registered
                [    0.536228] Key type id_legacy registered
                [    0.536257] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
                [    0.538107] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 2        51)
                [    0.538253] io scheduler noop registered
                [    0.538275] io scheduler deadline registered (default)
                [    0.538561] io scheduler cfq registered
                [    0.538583] io scheduler mq-deadline registered
                [    0.538603] io scheduler kyber registered
                [    0.541486] BCM2708FB: allocated DMA memory fad10000
                [    0.541532] BCM2708FB: allocated DMA channel 0 @ bb813000
                [    0.550101] Console: switching to colour frame buffer device 82x26
                [    0.558723] bcm2835-rng 3f104000.rng: hwrng registered
                [    0.561181] vc-mem: phys_addr:0x00000000 mem_base=0x3ec00000 mem_size:0x40000        000(1024 MiB)
                [    0.566350] vc-sm: Videocore shared memory driver
                [    0.568947] gpiomem-bcm2835 3f200000.gpiomem: Initialised: Registers at 0x3f2        00000
                [    0.583020] brd: module loaded
                [    0.593842] loop: module loaded
                [    0.596122] Loading iSCSI transport class v2.0-870.
                [    0.599102] libphy: Fixed MDIO Bus: probed
                [    0.601484] usbcore: registered new interface driver lan78xx
                [    0.603818] usbcore: registered new interface driver smsc95xx
                [    0.605979] dwc_otg: version 3.00a 10-AUG-2012 (platform bus)
                [    0.836189] Core Release: 2.80a
                [    0.838354] Setting default values for core params
                [    0.840594] Finished setting default values for core params
                [    1.043135] Using Buffer DMA mode
                [    1.045432] Periodic Transfer Interrupt Enhancement - disabled
                [    1.047800] Multiprocessor Interrupt Enhancement - disabled
                [    1.050225] OTG VER PARAM: 0, OTG VER FLAG: 0
                [    1.052626] Dedicated Tx FIFOs mode
                [    1.055327] WARN::dwc_otg_hcd_init:1046: FIQ DMA bounce buffers: virt = 0xbad        04000 dma = 0xfad04000 len=9024
                [    1.060024] FIQ FSM acceleration enabled for :
                               Non-periodic Split Transactions
                               Periodic Split Transactions
                               High-Speed Isochronous Endpoints
                               Interrupt/Control Split Transaction hack enabled
                [    1.071073] dwc_otg: Microframe scheduler enabled
                [    1.071155] WARN::hcd_init_fiq:459: FIQ on core 1 at 0x805e6a40
                [    1.073429] WARN::hcd_init_fiq:460: FIQ ASM at 0x805e6da8 length 36
                [    1.075693] WARN::hcd_init_fiq:486: MPHI regs_base at 0xbb87e000
                [    1.077982] dwc_otg 3f980000.usb: DWC OTG Controller
                [    1.080297] dwc_otg 3f980000.usb: new USB bus registered, assigned bus number        1
                [    1.082679] dwc_otg 3f980000.usb: irq 62, io mem 0x00000000
                [    1.085004] Init: Port Power? op_state=1
                [    1.087263] Init: Power Port (0)
                [    1.089645] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002
                [    1.091975] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=        1
                [    1.094275] usb usb1: Product: DWC OTG Controller
                [    1.096519] usb usb1: Manufacturer: Linux 4.14.34-v7+ dwc_otg_hcd
                [    1.098786] usb usb1: SerialNumber: 3f980000.usb
                [    1.101615] hub 1-0:1.0: USB hub found
                [    1.103828] hub 1-0:1.0: 1 port detected
                [    1.106387] dwc_otg: FIQ enabled
                [    1.106392] dwc_otg: NAK holdoff enabled
                [    1.106397] dwc_otg: FIQ split-transaction FSM enabled
                [    1.106407] Module dwc_common_port init
                [    1.106618] usbcore: registered new interface driver usb-storage
                [    1.108893] mousedev: PS/2 mouse device common for all mice
                [    1.111110] IR NEC protocol handler initialized
                [    1.113305] IR RC5(x/sz) protocol handler initialized
                [    1.115508] IR RC6 protocol handler initialized
                [    1.117681] IR JVC protocol handler initialized
                [    1.119756] IR Sony protocol handler initialized
                [    1.121883] IR SANYO protocol handler initialized
                [    1.123975] IR Sharp protocol handler initialized
                [    1.125966] IR MCE Keyboard/mouse protocol handler initialized
                [    1.127992] IR XMP protocol handler initialized
                [    1.130646] bcm2835-wdt 3f100000.watchdog: Broadcom BCM2835 watchdog timer
                [    1.133018] bcm2835-cpufreq: min=600000 max=1200000
                [    1.135478] sdhci: Secure Digital Host Controller Interface driver
                [    1.137604] sdhci: Copyright(c) Pierre Ossman
                [    1.140033] mmc-bcm2835 3f300000.mmc: could not get clk, deferring probe
                [    1.142530] sdhost-bcm2835 3f202000.mmc: could not get clk, deferring probe
                [    1.144830] sdhci-pltfm: SDHCI platform and OF driver helper
                [    1.148435] ledtrig-cpu: registered to indicate activity on CPUs
                [    1.150857] hidraw: raw HID events driver (C) Jiri Kosina
                [    1.153333] usbcore: registered new interface driver usbhid
                [    1.155638] usbhid: USB HID core driver
                [    1.158433] vchiq: vchiq_init_state: slot_zero = bad80000, is_master = 0
                [    1.162157] [vc_sm_connected_init]: start
                [    1.170936] [vc_sm_connected_init]: end - returning 0
                [    1.173819] Initializing XFRM netlink socket
                [    1.176195] NET: Registered protocol family 17
                [    1.178635] Key type dns_resolver registered
                [    1.181431] Registering SWP/SWPB emulation handler
                [    1.184383] registered taskstats version 1
                [    1.192633] uart-pl011 3f201000.serial: cts_event_workaround enabled
                [    1.195192] 3f201000.serial: ttyAMA0 at MMIO 0x3f201000 (irq = 87, base_baud        = 0) is a PL011 rev2
                [    1.201826] mmc-bcm2835 3f300000.mmc: mmc_debug:0 mmc_debug2:0
                [    1.204352] mmc-bcm2835 3f300000.mmc: DMA channel allocated
                [    1.262006] sdhost: log_buf @ bad07000 (fad07000)
                [    1.300675] mmc1: queuing unknown CIS tuple 0x80 (2 bytes)
                [    1.304658] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                [    1.308502] mmc1: queuing unknown CIS tuple 0x80 (3 bytes)
                [    1.313483] mmc1: queuing unknown CIS tuple 0x80 (7 bytes)
                [    1.321461] Indeed it is in host mode hprt0 = 00021501
                [    1.383577] mmc0: sdhost-bcm2835 loaded - DMA enabled (>1)
                [    1.386696] of_cfs_init
                [    1.388831] of_cfs_init: OK
                [    1.407250] Freeing unused kernel memory: 1024K
                [    1.498692] mmc1: new high speed SDIO card at address 0001
                [    1.520432] mmc0: host does not support reading read-only switch, assuming wr        ite-enable
                [    1.529035] mmc0: new high speed SDHC card at address aaaa
                [    1.531419] usb 1-1: new high-speed USB device number 2 using dwc_otg
                [    1.533836] Indeed it is in host mode hprt0 = 00001101
                [    1.596750] mmcblk0: mmc0:aaaa SL08G 7.40 GiB
                [    1.602519]  mmcblk0: p1 p2
                [    1.781785] usb 1-1: New USB device found, idVendor=0424, idProduct=9514
                [    1.784127] usb 1-1: New USB device strings: Mfr=0, Product=0, SerialNumber=0
                [    1.787492] hub 1-1:1.0: USB hub found
                [    1.790934] hub 1-1:1.0: 5 ports detected
                [    1.902516] at24 1-0057: 128 byte 24c01 EEPROM, writable, 1 bytes/write
                [    1.912615] rtc-ds1307 1-006f: registered as rtc0
                [    1.978808] i2c /dev entries driver
                [    2.111443] usb 1-1.1: new high-speed USB device number 3 using dwc_otg
                [    2.241827] usb 1-1.1: New USB device found, idVendor=0424, idProduct=ec00
                [    2.247432] usb 1-1.1: New USB device strings: Mfr=0, Product=0, SerialNumber        =0
                [    2.253287] smsc95xx v1.0.6
                [    2.354969] smsc95xx 1-1.1:1.0 eth0: register 'smsc95xx' at usb-3f980000.usb-        1.1, smsc95xx USB 2.0 Ethernet, b8:27:eb:3b:53:6f
                [    2.380054] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. O        pts: (null)
                [    3.096055] NET: Registered protocol family 10
                [    3.100116] Segment Routing with IPv6
                [    3.112592] ip_tables: (C) 2000-2006 Netfilter Core Team
                [    3.146397] systemd[1]: systemd 232 running in system mode. (+PAM +AUDIT +SEL        INUX +IMA +APPARMOR +SMACK +SYSVINIT +UTMP +LIBCRYPTSETUP +GCRYPT +GNUTLS +ACL +        XZ +LZ4 +SECCOMP +BLKID +ELFUTILS +KMOD +IDN)
                [    3.155059] systemd[1]: Detected architecture arm.
                [    3.159931] systemd[1]: Set hostname to <unipi>.
                [    3.167276] systemd[1]: Hardware watchdog 'Broadcom BCM2835 Watchdog timer',        version 0
                [    3.167361] systemd[1]: Set hardware watchdog to 10s.
                [    3.587377] systemd[1]: [/lib/systemd/system/evok.service:21] Unknown lvalue        'StartLimitIntervalSec' in section 'Service'
                [    3.635121] systemd[1]: Started Forward Password Requests to Wall Directory W        atch.
                [    3.640800] systemd[1]: Reached target Swap.
                [    3.644711] systemd[1]: Created slice User and Session Slice.
                [    3.650119] systemd[1]: Listening on udev Kernel Socket.
                [    3.941156] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
                [    4.010391] systemd-journald[223]: Received request to flush runtime journal        from PID 1
                [    4.666951] snd_bcm2835: module is from the staging directory, the quality is        unknown, you have been warned.
                [    4.669785] bcm2835_alsa bcm2835_alsa: card created with 8 channels
                [    4.840729] brcmfmac: F1 signature read @0x18000000=0x1541a9a6
                [    4.851008] brcmfmac: brcmf_fw_map_chip_to_name: using brcm/brcmfmac43430-sdi        o.bin for chip 0x00a9a6(43430) rev 0x000001
                [    4.851272] usbcore: registered new interface driver brcmfmac
                [    5.123838] brcmfmac: brcmf_c_preinit_dcmds: Firmware version = wl0: Oct 23 2        017 03:55:53 version 7.45.98.38 (r674442 CY) FWID 01-e58d219f
                [    5.124585] brcmfmac: brcmf_c_preinit_dcmds: CLM version = API: 12.2 Data: 7.        11.15 Compiler: 1.24.2 ClmImport: 1.24.1 Creation: 2014-05-26 10:53:55 Inc Data:        9.10.39 Inc Compiler: 1.29.4 Inc ClmImport: 1.36.3 Creation: 2017-10-23 03:47:1        4
                [    6.152333] uart-pl011 3f201000.serial: no DMA platform data
                [    6.475671] Adding 102396k swap on /var/swap.  Priority:-2 extents:1 across:1        02396k SSFS
                [    6.618805] random: crng init done
                [    6.625451] IPv6: ADDRCONF(NETDEV_UP): wlan0: link is not ready
                [    6.625470] brcmfmac: power management disabled
                [    6.962614] smsc95xx 1-1.1:1.0 eth0: hardware isn't capable of remote wakeup
                [    8.550145] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC1E        1
                [   10.615771] Bluetooth: Core ver 2.22
                [   10.615849] NET: Registered protocol family 31
                [   10.615856] Bluetooth: HCI device and connection manager initialized
                [   10.615876] Bluetooth: HCI socket layer initialized
                [   10.615889] Bluetooth: L2CAP socket layer initialized
                [   10.615920] Bluetooth: SCO socket layer initialized
                [   10.627765] Bluetooth: HCI UART driver ver 2.3
                [   10.627780] Bluetooth: HCI UART protocol H4 registered
                [   10.627786] Bluetooth: HCI UART protocol Three-wire (H5) registered
                [   10.628035] Bluetooth: HCI UART protocol Broadcom registered
                [   10.786346] Bluetooth: BNEP (Ethernet Emulation) ver 1.3
                [   10.786354] Bluetooth: BNEP filters: protocol multicast
                [   10.786368] Bluetooth: BNEP socket layer initialized
                [  429.106991] systemd[1]: apt-daily-upgrade.timer: Adding 29min 20.750225s rand        om time.
                [ 5867.054072] smsc95xx 1-1.1:1.0 eth0: link down
                [423864.359380] smsc95xx 1-1.1:1.0 eth0: link up, 100Mbps, full-duplex, lpa 0xC1        E1
                pi@L203-sn18:~ $
                root@L203-sn18:/home/pi# systemctl status unipitcp
                   Active: active (running) since Thu 2018-10-18 12:58:22 UTC; 4 days ago
                  Process: 1594 ExecStartPre=/bin/sh -c if [ "${FIRMWARE_UPDATE}" = "1" ]; then /opt/unipi-bin/fwspi --auto; fi (code=exited, status=0/SUCCESS)
                 Main PID: 1598 (unipi_tcp_serve)
                           └─1598 /opt/unipi-bin/unipi_tcp_server -p 502
                Warning: Journal has been rotated since unit was started. Log output is incomplete or unavailable.
                  @wizro_pl The thing is that the evok installed from debian package is not compatible with the one installed as mentioned on github. To make it easier, please use the Raspbian stretch lite and install evok according to the guide on Github. We will publish a UniPian OS with the package version of evok soon.
                  H 1 Reply Last reply Reply Quote 0
                  • H
                    HarishKumar @tomas_hora last edited by
                    @tomas_hora has this been done? Would it work now when we install a UniPian OS to Neuron L203 (bought in 2017)? When we checked, the services were all running as EVOK was pre-installed with the OS.
                      Right now it's best to use the install method starting from Raspbian (but currently only Raspbian Stretch). We are currently working on image build system which helps us to get faster releases of images and application updates (debian packages).
