1-Wire UTP cable color mapping
Hi all,
this afternoon I will cable my 1-wire temperature sensor network connecting to 1-wire hub.
I'm referring to this tutorial to prepare the connection to UTP cables. https://www.unipi.technology/tutorial/topology-of-1-wire-network-46What is not clear is the sequence of utp calbe color to use.
UTP cables have 4 twisted pair: orange/white-orange green/white-green blu/white-blu brown/white brown.
Do I need to use a particular color sequence to crimp the cable to RJ45 connector?Let me know
Antonio -
Hello @arolli,
if you are using UTP cable between Neuron/Axon and the 1-Wire hub, then it is safe to stick to the original network cable pinout (TIA-568B) on both sides:Best regards
Hi Martin,
I followed your indication and all my 5 thermostat are working fine.
I use autodetect and they are mapped as "1W-UniversalAi.1"
I'm able to see the temperature of all of them.
I've another question:
the devices I connected are "SEDtronic 1-Wire sensor variant: U1WTVS", they should measure the humidity too and .
How to read the humidity values?
Seem value VAD and VDD are connected to humidity and intensity of light, but need help to understand how to use them.
thank
Antonio -
Hello @arolli,
you'll need to use the Unica U1WT function for each sensor. It's a part of the Lib.UniPi which has to be added among the other references in the solution in Executable projects.
Hi Martin,
in my 1wire bus I've 3 HUB and several sensons. Everything is working fine.
Only problem appear when on the last port on my last hub I connected a rj45 splitter
( https://www.unipi.technology/1wire-hub-2-port-p50 ).
After a while I connect the thermometer to this hub it disconnect. (it appears red in mervis)
All RJ45 port are cabled whit pinout TIA-568B and thermometer are cabled as follow:+VCC: blu + blu/white
GND: brown + green/white
1W : green + brown/white.Do I need to use the same schema of connection on the thermometer atteched to 2 port splitter?
let me know if you have suggestion how to troubleshoot the problem.
Antonio
