    Websocket filter
    3475
      juntiedt last edited by
      I am trying to filter only the "temp" message out of the websocket application.
      Unfortunately it does not work. please have a look at my little test program:
      #!/usr/bin/python
      # -*- coding: utf-8 -*-
      import websocket
      import json
      from time import *
      from datetime import *
      def on_message(ws, message):
          obj = json.loads(message)
          print(str(obj))
      def on_error(ws, error):
          now = datetime.now().strftime('%H:%M:%S')
          print (error + ": " + now)
      def on_close(ws):
          print ("WS-Connection closed: " + now)
      #ws.send('{"cmd":"filter","devices":["ai","input"]}')
      def ws_receive():
          global ws
          global url
          ws = websocket.WebSocketApp(url, on_message = on_message, on_error = on_error, on_close = on_close)
          ws.run_forever()
      def ws_filter():
          global url
          ws = websocket.WebSocket()
          ws.connect(url)
          ws.send('{"cmd":"filter","devices":"temp"}')
          ws.close()
      def main():
          global url
          host = "localhost"
          url = "ws://%s/ws" %(host)
          ws_filter()
          ws_receive()
      if __name__ == "__main__":
          main()
        tomas_hora administrators @juntiedt last edited by
        @juntiedt https://forum.unipi.technology/topic/518/setting-filter-corrupts-the-websocket-message/4
          sorry, but does it mean, that there is a bug in evok?
          I don't quite understand what I should do to filter temp devices.
          What is wrong with my test program?
          Please have another look.
          thanks
            @juntiedt please try it with
            ws.send('{"cmd":"filter","devices":"[temp]"}')
              no success with the command you send :-(
                @juntiedt ok, then please wait until @tomas_knot gets back after Christmas or try to investigate the issue in the code of Evok
                  ok. In which directory should I look for the evok software?
