    1 wire net dies "Problem solved"
    23 Posts 4 Posters 16.5k Views 1 Watching
      tomas_hora administrators @zorro_66
      @zorro_66 Please test and report, any possibility to use shielded cable between the sensors?
      • W
        wizro_pl @zorro_66
        @zorro_66 did you connect shield to the ground ? it is necessary.
        • zorro_66Z
          zorro_66
          Yes as in the picture
          alt text
          • zorro_66Z
            zorro_66
            Now it has worked in two days
            My second Unipi do not have these problems
            where I have 20 pieces of sensors connected in a star network with no shielded cable.
            Does it help to update the software in Rpi.
            There seems to be some software errors.
            Just got home 2 1-Wire hub from Unipi.
            Can i connect with a standard RJ45 patch cable
            • zorro_66Z
              zorro_66
              Now, I have rebuilt my entire 1-wire network and used Unipi hub instead
              so now we will see if the network stops die
              alt text
              alt text
              • zorro_66Z
                zorro_66
                My 1-wire is incredibly unstable
                network dies at irregular intervals, showing unreasonable temperatures.
                I have rebuilt my net for spec from Unipi wiki shielded cat5 cable and hubs.
                But no difference 1-wire network die anyways.
                So it can not be anything wrong with the network itself, but the fault must be in Unipi alt. software.
                Grateful for help .
                alt text
                  @zorro_66 Can you try enabling the CRC check at the sensors? Just check the box in the sesors in the Scratchpad group. You might need to make the sensor as a custom and backup your project before playing with it
                  • zorro_66Z
                    zorro_66
                    I do not understand what you mean now
                      • zorro_66Z
                        zorro_66
                        aha tanks:thumbsup_tone3:
                        • zorro_66Z
                          zorro_66
                          Problem solved, I finally found a bad solder
                          at the VCC pin caused power loss in my 1-wire network
                          alt text
                          Reply Quote 1
                            We are sorry for that @zorro_66!
                            But it is really hard to find out this kind of issue during our test but we will update our testing procedures... Thanks for the info.
                            With your input, this post could be even better đź’—
