    Neuron with JSONPRC and python
      Juergen last edited by
      I would like to control the Neuron with evok / jsonrpc.
      I had downloaded from github the following:
      wget https://github.com/UniPiTechnology/evok/archive/v1.0.0.tar.gz
      after Installation without any errors I can't communicate with the Neuron.
      But if I put the SD-Card into an Raspberry with Unipi-Board it works
        tomas_hora administrators @Juergen last edited by
        @Juergen Support for Neuron in evok is not yet released. Please see https://github.com/UniPiTechnology/evok#testing-latest-git-versions
          after downloading the new version i can control the Neuron with the web Interface.
          But if i run the following program:
          #!/usr/bin/env python
          import jsonrpclib
          s=jsonrpclib.Server('http://192.168.200.133:8088/rpc')
          print("S:", s)
          print("Version", jsonrpclib.config.version)
          print(">>", s.relay_get(1))
          s.relay_set(1,1)
          i get this error:
          ('S:', <ServerProxy for 192.168.200.133:8088/rpc>)
          ('Version', 2.0)
          File "./MDE.py", line 6, in <module>
          File "/usr/local/lib/python2.7/dist-packages/jsonrpclib/jsonrpc.py", line 288, in call
          return self.__send(self.__name, args)
          File "/usr/local/lib/python2.7/dist-packages/jsonrpclib/jsonrpc.py", line 238, in _request
          check_for_errors(response)
          File "/usr/local/lib/python2.7/dist-packages/jsonrpclib/jsonrpc.py", line 567, in check_for_errors
          raise ProtocolError((code, message))
          jsonrpclib.jsonrpc.ProtocolError: (-32603, u'Internal Error')
          Any ideas ?
          best regards Jürgen
            @Juergen Relay 1 does not exists. Check the web interface of evok for correct identification. The correct identification is eg. 2_1
