    connecting 12v, 5v and 220v devices
      Boy Lenssen last edited by
      We are going to use the UniPi Neuron L20x to enable various devices, from 5 to 220 volts.
      Are there recommend power supplies for this to use?
        tomas_hora administrators @Boy Lenssen last edited by
        @Boy-Lenssen Do you mean you want to switch on/off devices by relays?
          Boy Lenssen @tomas_hora last edited by
          @tomas_hora yes, that is correct!
            @Boy-Lenssen Then it depends on the required power supply by the device connected behind the relay.
              @tomas_hora I am really not a hardware person. We now have this, well not exactly this one, it has DR-30-24 in there (it came with the UniPi I believe)...
              Is there also something like this you recommend using for powering the devices? You can think of devices like a smoke machine, but also lights
                @Boy-Lenssen DR-30-24 is the power supply recommended for used for powering the big Neurons.
                You need to see what is the power requirements of the device you will be using and choose the power supply accordingly. Eg. Neuron S103 requires 12W at 24VDC so people should use power supply that gives 24VDC and min 12W(0.5A). The same it is with any other device...
