    Setup sleep ratio
    4 Posts 2 Posters 2.5k Views
    • SorakCzS
      SorakCz
      I have simple program for switch on or switch off rele via DI. All working fine but there is wery slow reaction from UniPi. But if I change setting for PLC it don't work after change. I use Mervis 2.0.5 - 45059
      Thank You for helping
      Lukas
      alt text
        tomas_hora administrators
        Basically that is the limit of how fast Mervis scans the DIs. In order to set the sleep ratio to lower, you need than switch back to the profile LAN or proxy.
        SorakCzS 1 Reply Last reply
        • SorakCzS
          SorakCz @tomas_hora
          @tomas_hora Thank you and how can I do it?
            @SorakCz The image that was posted here was OK! You just needed to switch back to your LAN/proxy profile.
