    Which software should I use for 13 blinds and shutters?
    Scheduled Pinned Locked Moved General Discussion
    17 Posts 2 Posters 8.8k Views
      tomas_hora administrators
      nice application :) It would be great if you share your progress and result here.
      I think that FHEM would be the solution. There are commercial platforms but it wont meet the EnOceand and HomeMatic requirements.
      FHEM is not officially supported, however implementation is pretty easy because we provide TCP modbus interface to read/control the IOs and FHEM is capable of TCP modbus too....
        armin
        Thank you for the fast answer.
        I am not sure if it is "pretty easy" for me. I have never worked with Modbus, FHEM or PEARL before.
        Where could i download the "TCP modbus" firmware? I guess Products->Neuron->firmware but which file?
        Cold i try with my own RaspberryPi or does the system not start without slave controllers?
          I will create a github repository next week where all the required steps to make the TCP modbus work will be described (or even automatized with a script).
          Right now it is only implemented in the mervis image available in downloads. So you can use that one too.
            armin
            my Neuron L203 arrived and i now have the time for system setup.
            Installing Raspian was no problem and its running fine now.
            With your manual at neuron_tcp_modbus_overlay i tried to install the modbus TCP server.
            First small problem was that with
            bash neuron_tcp_modbus_overlay-1.0.0/install.sh
            the scipt fails because of wrong paths. It works with:
            wget https://github.com/UniPiTechnology/neuron_tcp_modbus_overlay/archive/v1.0.0.zip
            unzip v1.0.0.zip
            cd ./neuron_tcp_modbus_overlay-1.0.0/
            sudo bash ./install.sh
            After reboot i can see with htop that "/opt/neurontcp/neuron_tcp_server -p 502 --check-firmware" is running.
            The RUN1, RUN2 and RUN3 LEDs are still blinking with 2 seconds on and 2 seconds off. According to the manual this means "Communication timeout reached MWD".
            Did the installation really work as it should?
            How can i check if the server runs correct?
            Is there an easy way to switch relay 2.1 ON with command line?
              Have you tried to run the server manually by hand? Could you paste the output of that?
              Also see the output of the installation script if everything goes well.
                armin
                running installation again:
                pi@raspberrypi:~/neuron_tcp_modbus_overlay-1.0.0 $ sudo bash ./install.sh
                Installing libmodbus
                Ign http://dl.bintray.com stable InRelease
                OK   http://archive.raspberrypi.org jessie InRelease
                OK   http://mirrordirector.raspbian.org jessie InRelease
                Holen: 1 http://dl.bintray.com stable Release.gpg [821 B]
                Holen: 2 http://dl.bintray.com stable Release [6.050 B]
                OK   http://archive.raspberrypi.org jessie/main armhf Packages
                OK   http://archive.raspberrypi.org jessie/ui armhf Packages
                OK   http://mirrordirector.raspbian.org jessie/main armhf Packages
                OK   http://mirrordirector.raspbian.org jessie/contrib armhf Packages
                Holen: 3 http://dl.bintray.com stable/main armhf Packages [77,8 kB]
                OK   http://mirrordirector.raspbian.org jessie/non-free armhf Packages
                OK   http://mirrordirector.raspbian.org jessie/rpi armhf Packages
                Ign http://dl.bintray.com stable/main Translation-de_DE
                Ign http://dl.bintray.com stable/main Translation-en
                Ign http://archive.raspberrypi.org jessie/main Translation-de_DE
                Ign http://archive.raspberrypi.org jessie/main Translation-en
                Ign http://archive.raspberrypi.org jessie/ui Translation-de_DE
                Ign http://archive.raspberrypi.org jessie/ui Translation-en
                Ign http://mirrordirector.raspbian.org jessie/contrib Translation-de_DE
                Ign http://mirrordirector.raspbian.org jessie/contrib Translation-en
                Ign http://mirrordirector.raspbian.org jessie/main Translation-de_DE
                Ign http://mirrordirector.raspbian.org jessie/main Translation-en
                Ign http://mirrordirector.raspbian.org jessie/non-free Translation-de_DE
                Ign http://mirrordirector.raspbian.org jessie/non-free Translation-en
                Ign http://mirrordirector.raspbian.org jessie/rpi Translation-de_DE
                Ign http://mirrordirector.raspbian.org jessie/rpi Translation-en
                Es wurden 84,6 kB in 10 s geholt (8.192 B/s).
                Paketlisten werden gelesen... Fertig
                Abhängigkeitsbaum wird aufgebaut.
                Statusinformationen werden eingelesen.... Fertig
                libmodbus-dev ist schon die neueste Version.
                0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                Enabling SPI overlay
                Warning (unit_address_vs_reg): Node /fragment@0 has a unit name, but no reg property
                Warning (unit_address_vs_reg): Node /fragment@1 has a unit name, but no reg property
                mkdir: das Verzeichnis „/opt/neurontcp“ kann nicht angelegt werden: Die Datei existiert bereits
                Compiling neurontcp server...
                make: Nothing to be done for 'all'.
                Installing Neuron TCP server into /opt/neurontcp/
                Enabling neurontcp service for systemd
                Created symlink from /etc/systemd/system/neurontcp.service to /lib/systemd/system/neurontcp.service.
                Created symlink from /etc/systemd/system/multi-user.target.wants/neurontcp.service to /lib/systemd/system/neurontcp.service.
                Reboot is required. Is it OK to reboot now? [y/n]
                after reboot:
                pi@raspberrypi:~ $ /opt/neurontcp/neuron_tcp_server -p 502 --check-firmware
                modbus_tcp_listen: Permission denied
                Abgebrochen
                pi@raspberrypi:~ $ sudo /opt/neurontcp/neuron_tcp_server -p 502 --check-firmware
                modbus_tcp_listen: Address already in use
                pi@raspberrypi:~ $ sudo systemctl disable neurontcp.service
                Removed symlink /etc/systemd/system/neurontcp.service.
                Removed symlink /etc/systemd/system/multi-user.target.wants/neurontcp.service.
                again reboot:
                New connection from 127.0.0.1:44698 on socket 13
                Closed connection on descriptor 13
                New connection from 127.0.0.1:45210 on socket 13
                New connection from 127.0.0.1:45722 on socket 13
                New connection from 127.0.0.1:46234 on socket 13
                New connection from 127.0.0.1:46746 on socket 13
                New connection from 127.0.0.1:47258 on socket 13
                New connection from 127.0.0.1:47770 on socket 13
                New connection from 127.0.0.1:48282 on socket 13
                New connection from 127.0.0.1:48794 on socket 13
                New connection from 127.0.0.1:49306 on socket 13
                New connection from 127.0.0.1:49818 on socket 13
                New connection from 127.0.0.1:50330 on socket 13
                New connection from 127.0.0.1:50842 on socket 13
                New connection from 127.0.0.1:51354 on socket 13
                New connection from 127.0.0.1:51866 on socket 13
                New connection from 127.0.0.1:52378 on socket 13
                New connection from 127.0.0.1:52890 on socket 13
                New connection from 127.0.0.1:53402 on socket 13
                New connection from 127.0.0.1:53914 on socket 13
                New connection from 127.0.0.1:54426 on socket 13
                New connection from 127.0.0.1:54938 on socket 13
                New connection from 127.0.0.1:55450 on socket 13
                New connection from 127.0.0.1:55962 on socket 13
                New connection from 127.0.0.1:56474 on socket 13
                New connection from 127.0.0.1:56986 on socket 13
                New connection from 127.0.0.1:57498 on socket 13
                New connection from 127.0.0.1:58010 on socket 13
                  armin
                  The above logs were done with openHAB installation on the same Pi. To make clear that i don't have a problem with the not configured openHAB i have done an new clean installation:
                  • download image from: Raspbian Jessie with PIXEL 2016-11-25
                  • copy to sd-card
                  • change locales and enable ssh with rc_gui
                  • installed with script:
                  pi@raspberrypi:~ $ wget https://github.com/UniPiTechnology/neuron_tcp_modbus_overlay/archive/v1.0.0.zip
                  --2016-12-02 20:07:00--  https://github.com/UniPiTechnology/neuron_tcp_modbus_overlay/archive/v1.0.0.zip
                  Auflösen des Hostnamen »github.com (github.com)«... 192.30.253.113, 192.30.253.112
                  Verbindungsaufbau zu github.com (github.com)|192.30.253.113|:443... verbunden.
                  HTTP-Anforderung gesendet, warte auf Antwort... 302 Found
                  Platz: https://codeload.github.com/UniPiTechnology/neuron_tcp_modbus_overlay/zip/v1.0.0[folge]
                  --2016-12-02 20:07:01--  https://codeload.github.com/UniPiTechnology/neuron_tcp_modbus_overlay/zip/v1.0.0
                  Auflösen des Hostnamen »codeload.github.com (codeload.github.com)«... 192.30.253.120, 192.30.253.121
                  Verbindungsaufbau zu codeload.github.com (codeload.github.com)|192.30.253.120|:443... verbunden.
                  HTTP-Anforderung gesendet, warte auf Antwort... 200 OK
                  Länge: nicht spezifiziert [application/zip]
                  In »»v1.0.0.zip«« speichern.
                  v1.0.0.zip              [  <=>                 ]  38,20K   155KB/s   in 0,2s
                  2016-12-02 20:07:02 (155 KB/s) - »v1.0.0.zip« gespeichert [39120]
                  pi@raspberrypi:~ $ unzip v1.0.0.zip
                  Archive:  v1.0.0.zip
                  d66ef41199393d9b095c0acd43910f2aeac4e5e7
                     creating: neuron_tcp_modbus_overlay-1.0.0/
                    inflating: neuron_tcp_modbus_overlay-1.0.0/LICENSE
                    inflating: neuron_tcp_modbus_overlay-1.0.0/README.md
                    inflating: neuron_tcp_modbus_overlay-1.0.0/install.sh
                     creating: neuron_tcp_modbus_overlay-1.0.0/neuron_tcp_server/
                    inflating: neuron_tcp_modbus_overlay-1.0.0/neuron_tcp_server/Makefile
                    inflating: neuron_tcp_modbus_overlay-1.0.0/neuron_tcp_server/README.md
                    inflating: neuron_tcp_modbus_overlay-1.0.0/neuron_tcp_server/armpty.c
                    inflating: neuron_tcp_modbus_overlay-1.0.0/neuron_tcp_server/armpty.h
                    inflating: neuron_tcp_modbus_overlay-1.0.0/neuron_tcp_server/armspi.c
                    inflating: neuron_tcp_modbus_overlay-1.0.0/neuron_tcp_server/armspi.h
                    inflating: neuron_tcp_modbus_overlay-1.0.0/neuron_tcp_server/bandwidth-client.c
                    inflating: neuron_tcp_modbus_overlay-1.0.0/neuron_tcp_server/nb_modbus.c
                    inflating: neuron_tcp_modbus_overlay-1.0.0/neuron_tcp_server/nb_modbus.h
                    inflating: neuron_tcp_modbus_overlay-1.0.0/neuron_tcp_server/neuron_tcp_server.c
                    inflating: neuron_tcp_modbus_overlay-1.0.0/neuron_tcp_server/neuronspi.c
                    inflating: neuron_tcp_modbus_overlay-1.0.0/neuron_tcp_server/neurontcp.service
                    inflating: neuron_tcp_modbus_overlay-1.0.0/neuron_tcp_server/spicrc.c
                    inflating: neuron_tcp_modbus_overlay-1.0.0/neuron_tcp_server/spicrc.h
                     creating: neuron_tcp_modbus_overlay-1.0.0/spi_overlay/
                    inflating: neuron_tcp_modbus_overlay-1.0.0/spi_overlay/compile-dtc
                    inflating: neuron_tcp_modbus_overlay-1.0.0/spi_overlay/neuron-spi.dts
                  pi@raspberrypi:~ $ cd ./neuron_tcp_modbus_overlay-1.0.0/
                  Die folgenden Pakete wurden automatisch installiert und werden nicht mehr benötigt:
                    libboost-filesystem1.55.0 libboost-program-options1.55.0 libboost-regex1.55.0 libcwiid1 libjs-prettify libqscintilla2-11 libqscintilla2-l10n libqt4-network libqt4-xmlpatterns libqtwebkit4 libruby1.9.1 libruby1.9.1-dbg libtcl8.5
                    libtcltk-ruby1.9.1 libtk8.5 ri1.9.1 ruby1.9.1 ruby1.9.1-dev ruby1.9.1-examples ruby1.9.1-full ruby1.9.3 supercollider supercollider-common supercollider-ide supercollider-language supercollider-supernova tcl8.5 tk8.5
                  Verwenden Sie »apt-get autoremove«, um sie zu entfernen.
                  Die folgenden zusätzlichen Pakete werden installiert:
                    libmodbus5
                  Die folgenden NEUEN Pakete werden installiert:
                    libmodbus-dev libmodbus5
                  0 aktualisiert, 2 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
                  Es müssen 97,9 kB an Archiven heruntergeladen werden.
                  Nach dieser Operation werden 140 kB Plattenplatz zusätzlich benutzt.
                  Holen: 1 http://mirrordirector.raspbian.org/raspbian/ jessie/main libmodbus-dev armhf 3.0.6-1 [77,0 kB]
                  Holen: 2 http://mirrordirector.raspbian.org/raspbian/ jessie/main libmodbus5 armhf 3.0.6-1 [20,9 kB]
                  Es wurden 97,9 kB in 1 s geholt (82,8 kB/s).
                  Vormals nicht ausgewähltes Paket libmodbus5:armhf wird gewählt.
                  (Lese Datenbank ... 130665 Dateien und Verzeichnisse sind derzeit installiert.)
                  Vorbereitung zum Entpacken von .../libmodbus5_3.0.6-1_armhf.deb ...
                  Entpacken von libmodbus5:armhf (3.0.6-1) ...
                  Vormals nicht ausgewähltes Paket libmodbus-dev wird gewählt.
                  Vorbereitung zum Entpacken von .../libmodbus-dev_3.0.6-1_armhf.deb ...
                  Entpacken von libmodbus-dev (3.0.6-1) ...
                  Trigger für man-db (2.7.0.2-5) werden verarbeitet ...
                  libmodbus5:armhf (3.0.6-1) wird eingerichtet ...
                  libmodbus-dev (3.0.6-1) wird eingerichtet ...
                  Trigger für libc-bin (2.19-18+deb8u6) werden verarbeitet ...
                  gcc -g -c  -I .  armspi.c -o armspi.o
                  gcc -g -c  -I .  spicrc.c -o spicrc.o
                  gcc -g -c  -I .  nb_modbus.c -o nb_modbus.o
                  gcc -g -c  -I .  armpty.c -o armpty.o
                  gcc -g -c  -I .  neuron_tcp_server.c -o neuron_tcp_server.o
                  gcc -g neuron_tcp_server.o armspi.o spicrc.o nb_modbus.o armpty.o  -lmodbus -lutil -o neuron_tcp_server
                  gcc -g -c  -I .  neuronspi.c -o neuronspi.o
                  gcc -g neuronspi.o armspi.o spicrc.o -o neuronspi
                  gcc -g -c  -I .  bandwidth-client.c -o bandwidth-client.o
                  gcc -g bandwidth-client.o armspi.o spicrc.o nb_modbus.o armpty.o  -lmodbus -lutil -o bandwidth-client
                  • two warnings occurred:
                  are they relevant?
                  • after reboot:
                  pi@raspberrypi:~ $ systemctl status neurontcp
                  ? neurontcp.service - Unipi Neuron Modbus/Tcp Server
                     Loaded: loaded (/lib/systemd/system/neurontcp.service; enabled)
                     Active: active (running) since Fr 2016-12-02 20:12:19 CET; 6min ago
                   Main PID: 404 (neuron_tcp_serv)
                     CGroup: /system.slice/neurontcp.service
                             +-404 /opt/neurontcp/neuron_tcp_server -p 502 --check-firmware
                  pi@raspberrypi:~ $ sudo systemctl stop neurontcp.service
                     Active: inactive (dead) since Fr 2016-12-02 20:19:13 CET; 4s ago
                    Process: 404 ExecStart=/opt/neurontcp/neuron_tcp_server -p 502 --check-firmware (code=killed, signal=TERM)
                   Main PID: 404 (code=killed, signal=TERM)
                  pi@raspberrypi:~ $
                  Abgebrochen
                  no further message for 4 hours...
                  It seams that the "New connection from 127.0.0.1:45210 on socket 13" messages from the first install were caused by openHAB or something else i have done playing around.
                  Could you please give me some hint what i am doing wrong or is the blinking normal without active connection to the server?
                    Alright I have not tested it with the PIXEL desktop, but only with the lite version. But it should not make any difference.
                    How many devices do you see in /dev/spi*
                      armin
                      4 devices:
                      • spidev0.0
                      • spidev0.1
                      • spidev0.2
                      • spidev0.3
                        That looks OK. Are you sure there is no output after you run the daemon manually? There must be something :)
                          armin
                          Yes i am sure. Shall i take a video?
                            Ok, please run it with more verbose output and pate the output:
                            /opt/neurontcp/neuron_tcp_server -p 502 --check-firmware -vvv
                              armin
                              pi@raspberrypi:~ $ sudo /opt/neurontcp/neuron_tcp_server -p 502 --check-firmware -vvv
                              Board on /dev/spidev0.1 firmware=4.6  hardware=0.16 (B-1000-1)
                              Board on /dev/spidev0.3 firmware=4.6  hardware=8.16 (E-16Di-1_U-14Ro-1)
                              Board on /dev/spidev0.2 firmware=4.6  hardware=8.16 (E-16Di-1_U-14Ro-1)
                              Board0 PTY0 /dev/pts/1
                              Starting loop
                              and then nothing more for two hours
                                tomas_hora administrators @armin
                                @armin this means that the hw and sw (tcp modbus server) is working ok. Now it is ut to you to send the commands...
                                You shouldd use the modbus protocolfor communicating with neuron - see the modbus map of your device at downloads.unipi.technology
                                So far no command line tool. But modbus is pretty easy.
                                  armin
                                  the LEDs are still blinking (2 seconds on, 2 seconds off).
                                  Is this normal behavior if no client is connected to the server?
                                    According to the manual: https://files.unipi.technology/index.php/s/zTmrEbQEvifNd6W?path=%2FProducts%2FNeuron%2FDocumentation#pdfviewer
                                    chapter 2.2.1 LED diodedescription
                                    and later MWD description. It means you do not communicate with the devices. Which is also notable that there is no output when you run the server by hand.
