    4RO 4DI expansion module
    REX
    5780
      Thokoane last edited by
      Hello
      I've recently bought two expansion modules from unipi. And would like to know how to communicate with both the modules using a one wire system. In my project i have the rasberry pi connected to the unipi and would like to add this two expansion module, this are 1w 4 DI 4RO expansion modules
        Do you plan to use evok or what sw to read/set the IOs?
          Hi
          Am currently using Rex Controls.
            Hello, sorry I should have get it from the topic category.
            I think @jaroslav_sobota should be able to help you with that.
              Hi
              Out of curosity if am communicating with these two expansion boards do I have to have my I2C enabled on my unipi
                When am using the owdir command am not able to detect the 2 expansion modules that I've connected on the unipi using the 1 wire system
                  jaroslav_sobota last edited by
                  Did you edit the /etc/owfs.conf file? It should contain the following:
                  !server: server = 127.0.0.1:4304
                  allow_other
                  server: port = 127.0.0.1:4304
                  server: i2c=ALL:ALL
                  timeout_volatile = 2
                  You will need to restart owserver for these settings to have effect. Or reboot the Raspberry Pi.
                  Can you post here the output of the owdir command? Please start with only 1 expansion module.
                  Jaroslav
                    Hi my project is fully functional thanks to you all
