    OWFS server
    • zorro_66
      zorro_66 last edited by
      Is it possible to get temperature readings from a OWFS server over the lan tcp/ip
      • zorro_66
          Guest last edited by
          The thing is that mervis does not uses owfs server but only the 1-wire kernel module. But if you map your temperature sensors in Mervis, you can then pam the variable to a TCP modbus server and there are many libraries and examples online for reading that….
          • zorro_66
            OK
            I have a OWFS server today I read in about 50 sensors from that, I would like to read in the mervis.
            Then I think about and put them directly in Unipi
            Can Unipi handle 50 1-wire sensors
              See the documentation: http://unipi.technology/wiki/1Wire_topology but it also depends on your installation
              • zorro_66
                OK
                I will try to see what happens
                Just ordered my second Unipi for lab purposes
                My first Unipi control my chillers for my server racks
                [attachment=0:zhfhxnxj]System.png[/attachment:zhfhxnxj]
