    Call function block from st
    • S
      soren last edited by
      Hello there,
      I have just started to migrate to ST - these big diagrams gets messy in the long run ;)
      Now I'm just trying to call a function block from st.
      But i always get 'no value'.
      My question is, how do I call ph_control_hourly and get the value of the variable 'out'?
      Thanks a lot
        Martin Kudláček administrators @soren last edited by
        Hello @søren-hedegaard-0,
        you didn't pass any input value to the ph_control_hourly(), so the block doesn't know anything about run_at_time and ph_hourly_feed.
        The call should look this:
        ph_control_hourly(run_at_time := local_run_at_time, ph_hourly_feed := local_ph_hourly_feed, out => local_out_value)
        If you look in to the help (F1) of any built-in FB, you will see a usage and you learn how the ST works:
