Raspberry Pi Zero
Will the UniPi works with Raspberry Pi Zero?
GPIO pinout should be the same.
I did not have a chance to test it but it definitely should! If you need a standalone PLC like, then it is a perfect match
Let me know if you got one in hands and test it with UniPi
I get some extra Pi Zero now
It's working with no issue on Unipi. Just a little acrobatic to get it fix
For GPIO connexion, I get some bad result with a 40->26 cable, so I have take a pi zero, solder only 26GPIO on it and it's working like with the old Pi B
@tomas_hora look for a support that can be used for Pi Zero in next Unipi, for autonomous automat it's enough and really a match this little thing
