Mervis DB with Matlab
I fiddled around with the Matlab Mervis DB toolbox (https://kb.mervis.info/doku.php/en:mervis-db:10-api). Unfortunately i di not manage to download data from the database. The problem seem to be with theMexMain.mexw64file. For the.mexfile to run somedlls are required. Those can be installed with the Visual Studio C++ Runtime.
The problem is that theMexMain.mexw64file is compile in debug mode not in release mode. For the debug version to run the original debugdlls are required.Could anybody responsible provide me with a .mex-file compile in release mode? Or any other way to make it run.
Otherwise I would be happy about a solution to retrieve and manipulate data in the Mervis DB with either Matlab or Python
Hi, the mex file is compiled from C++ source code. The MexMain.mexw64 file is compiled for Windows 64bit platform. I do suggest that you use Windows 64bit.
What version of Matlab do you use?
