    HTTP request bulk group assignment
      juntiedt last edited by
      Hi, sending a bulk request group assignment to relays, only the last relay switches on. all others just click without switching. It seems that the bulk request is too fast for the unpi 1.1. relays. Can you confirm this?
        Martin Kudláček @juntiedt last edited by
        Hi @juntiedt,
        can you please share your code for bulk request?
        Thanks,
          this is my code within node-red
          msg.url = "http://10.0.0.52:8080/bulk";
          msg.headers = '{"content-type":"application/json"}';
          msg.payload = '{"group_assignments": [{"device_type":"relay","assigned_values":{"value": 1}}]}';
          return msg;
          [{"id":"513c2375.8dd04c","type":"function","z":"8737dbc7.9d0da8","name":"Bulk Relay on","func":"msg.url = \"http://10.0.0.52:8080/bulk\";\nmsg.headers = '{\"content-type\":\"application/json\"}';\nmsg.payload = '{\"group_assignments\": [{\"device_type\":\"relay\",\"assigned_values\":{\"value\": 1}}]}';\nreturn msg;\n","outputs":1,"noerr":0,"x":300,"y":480,"wires":[["aeccdaf4.9f6458"]]},{"id":"aeccdaf4.9f6458","type":"http request","z":"8737dbc7.9d0da8","name":"","method":"POST","ret":"txt","paytoqs":false,"url":"","tls":"","proxy":"","authType":"basic","x":530,"y":500,"wires":[[]]},{"id":"44fd9776.d524a8","type":"function","z":"8737dbc7.9d0da8","name":"Bulk Relay off","func":"msg.url = \"http://10.0.0.52:8080/bulk\";\nmsg.headers = '{\"content-type\":\"application/json\"}';\nmsg.payload = '{\"group_assignments\": [{\"device_type\":\"relay\",\"assigned_values\":{\"value\": 0}}]}';\nreturn msg;\n","outputs":1,"noerr":0,"x":300,"y":520,"wires":[["aeccdaf4.9f6458"]]},{"id":"79d7a128.535bb","type":"inject","z":"8737dbc7.9d0da8","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":120,"y":480,"wires":[["513c2375.8dd04c"]]},{"id":"507fa2db.5a945c","type":"inject","z":"8737dbc7.9d0da8","name":"","topic":"","payload":"","payloadType":"date","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":120,"y":520,"wires":[["44fd9776.d524a8"]]}]```
            the slow version works ok
            [{"id":"fafe105b.048f4","type":"function","z":"8737dbc7.9d0da8","name":"","func":"\nvar rn = parseInt(flow.get('loops'));\nvar onoff = parseInt(flow.get('onoff'));\nmsg.payload = [rn,onoff,0]; \nreturn msg;","outputs":1,"noerr":0,"x":430,"y":300,"wires":[["7989a53f.33b07c","e711aba3.e2aa38"]]},{"id":"7989a53f.33b07c","type":"function","z":"8737dbc7.9d0da8","name":"","func":"var rmax = flow.get('count');\nvar cnt = flow.get('loops');\ncnt = cnt +1;\nflow.set('loops',cnt);\nif (cnt <= rmax){\n    return msg;\n}    ","outputs":1,"noerr":0,"x":430,"y":380,"wires":[["63b8469f.9604a8"]]},{"id":"554d2bad.2071a4","type":"function","z":"8737dbc7.9d0da8","name":"","func":"flow.set('count',8);\nflow.set('loops',1);\nflow.set('onoff', msg.payload);\nmsg.payload = msg.payload;\nreturn msg;","outputs":1,"noerr":0,"x":290,"y":300,"wires":[["fafe105b.048f4"]]},{"id":"63b8469f.9604a8","type":"delay","z":"8737dbc7.9d0da8","name":"","pauseType":"delay","timeout":"70","timeoutUnits":"milliseconds","rate":"1","nbRateUnits":"1","rateUnits":"second","randomFirst":"1","randomLast":"5","randomUnits":"seconds","drop":false,"x":430,"y":340,"wires":[["fafe105b.048f4"]]},{"id":"e711aba3.e2aa38","type":"function","z":"8737dbc7.9d0da8","name":"post","func":"var rn = (msg.payload[0]).toString();\nvar rv = (msg.payload[1]).toString();\nvar rt = (msg.payload[2]).toString();\nmsg.url = \"http://10.0.0.52:8080/json/relay/\" + rn;\nmsg.headers = '{\"content-type\":\"application/json\"}';\nif (rt == \"0\"){\n    msg.payload = '{\"value\": \"' + rv +'\"}';\n}\nelse {\n    msg.payload = '{\"value\": \"' + rv +'\",\"timeout\": \"' + rt + '\"}';\n}    \nreturn msg;\n","outputs":1,"noerr":0,"x":570,"y":300,"wires":[["56eb0da5.2e5ad4"]]},{"id":"56eb0da5.2e5ad4","type":"http request","z":"8737dbc7.9d0da8","name":"","method":"POST","ret":"txt","paytoqs":false,"url":"","tls":"","proxy":"","authType":"basic","x":730,"y":300,"wires":[[]]},{"id":"6e845bbf.8ec644","type":"inject","z":"8737dbc7.9d0da8","name":"alle Relays on","topic":"","payload":"1","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":280,"wires":[["554d2bad.2071a4"]]},{"id":"85d78b7b.ebab08","type":"inject","z":"8737dbc7.9d0da8","name":"alle Relays off","topic":"","payload":"0","payloadType":"str","repeat":"","crontab":"","once":false,"onceDelay":0.1,"x":130,"y":320,"wires":[["554d2bad.2071a4"]]},{"id":"f0c0d75e.a119f8","type":"ui_button","z":"8737dbc7.9d0da8","name":"","group":"fcc9c186.32f2d","order":1,"width":0,"height":0,"passthru":false,"label":"alle Relays on","tooltip":"","color":"","bgcolor":"","icon":"","payload":"1","payloadType":"str","topic":"","x":120,"y":240,"wires":[["554d2bad.2071a4"]]},{"id":"bea16915.e5a998","type":"ui_button","z":"8737dbc7.9d0da8","name":"","group":"fcc9c186.32f2d","order":3,"width":0,"height":0,"passthru":false,"label":"alle Relays aus","tooltip":"","color":"","bgcolor":"","icon":"","payload":"0","payloadType":"str","topic":"","x":120,"y":360,"wires":[["554d2bad.2071a4"]]},{"id":"fcc9c186.32f2d","type":"ui_group","z":"","name":"","tab":"275e79b3.d6faf6","order":1,"disp":false,"width":"8","collapse":false},{"id":"275e79b3.d6faf6","type":"ui_tab","z":"","name":"R","icon":"dashboard","order":4,"disabled":false,"hidden":false}]```
              Hi Martin, still waiting for a response. Are you not supporting node-Red?
                Hello @juntiedt,
                I'm sorry for not getting back to you in timely manner. This error is in the Evok and we have created a bugfix. Next week we will release a fixed package and if everything goes well today, the source code will be available on the Evok's Github.
                hank you for your patience and have a good day,
