    io.writeport TCP
      JasperJackson last edited by
      Hello all!
      I'm trying to implement a very simple ASCII tcp protocoll to control some ali-express ethernet relais.
      The protocoll is very very easy, no security.
      ASCII string: 11 pulls relay 1
      ASCII string: 21 releases relay 1
      So, this works when using packetsender from my phone, works when using packetsender from my laptop. But it doesn't work using io.writeport from a ST file.
      Using wireshark i found out that communication is working, but the packets are not valid (len=0). So i'm doing something wrong.
      The code sending the string is as follows:
      FUNCTION_BLOCK EthernetRelais
      EXTENDS //base type
      IMPLEMENTS //interface type list
      	VAR
      		connection 	: string;
      		conn_handle	: io.commhandle;
      		fsm			: int := 0;
      		command		: array[0..10] of byte;
      		local_state : byte := 0;
      		initial		: bool := 1;
      		portstatus : int;
      		timeout : int;
      		i : int;
      		(* add local variables here *)
      	END_VAR
      	VAR_INPUT
      		(* add in variables here *)
      		state : bool;
      	END_VAR
      	VAR_OUTPUT
      		(* add out variables here *)
      		current_state : bool;
      	END_VAR
      	case fsm OF
      		0:
      			if state <> local_state or initial THEN
      				local_state := state;
      				fsm := 1;
      				initial := false;
      				timeout := 1000;
      				END_IF;
      		1:
      			connection := 'tcp:192.168.1.5:6722';
      			conn_handle := io.openport(connection);
      			fsm := 2;
      		2:
      			portstatus := io.getportstatus(conn_handle);
      			if  portstatus = 0 THEN
      				fsm := 3;
      			END_IF;
      			timeout := timeout -1;
      			if timeout = 0 THEN
      			io.closeport(conn_handle);
      			fsm := 0;
      			END_IF;
      		3:
      				if local_state = 1 THEN
      					command[0] := 49;
      					command[1] := 49;
      				ELSE
      					command[0] := 50;
      					command[1] := 49;
      				END_IF;
      			io.writeport(conn_handle,adr command[0],10);
      			fsm := 0;
      		ELSE
      			fsm := 0;
      end_case;
      METHOD abc //: return type
        // method's body
      END_METHOD
      (*function block body*)
      END_FUNCTION_BLOCK
      This is the output of wireshark:
      192.168.1.5 is my laptop
      192.168.1.7 is my unipi
      This is the communication of the ST code only. No idea why everything has zero length. And my data is nowhere to be found in the packages.
      Any help would be appreciated!
      Regards,
      Jasper Jackson
        JasperJackson @JasperJackson last edited by
        @jasperjackson said in io.writeport TCP:
        Got it... one has to keep calling
        until it returns true :)
