Navigation
    Pulse flow meter
    Other Peripherals
    • Q
      QComp last edited by
      Re: Flow meter
      do you have experience with these pulse flow meters?
      http://chnsensor.com/2ProductsShow.asp?id=2238&BigClassID=108&SmallClassid=7#topa
      or
      http://www.chinaexpress.cz/cs/item/Aiyima-Water-Flow-Sensor-Switch-Flowmeter-Level-Water-Control-2-45L-min-G3-4-Liquid-Sensor/32836373123.html
      or
      https://www.sika.net/en/services/downloads/send/276-turbinen-durchflusssensoren-turbine-flow-sensors/1868-turbinen-durchflusssensoren-turbine-flow-sensors-vty.html
      or any other flow meters and integration to Mervis ?
        Martin Kudláček administrators @QComp last edited by
        Hello @qcomp we don't have direct experience with these devices, but it is quite simple to connect them to our PLCs through Digital Inputs. I recommend looking into our Counters functionality which can give you more precise results during high water consumption periods. The process is the same as measuring electricity consumption through S0 output of energy meters - 1 pulse equals to some defined amout of energy / water .
