    RS485 Modbus 8 Analogue Outputs
    Other Peripherals
      robl last edited by
      I need some additional analogue outputs for Neuron, and was wondering if this module would be compatible via MODBUS and possible to add?
      http://www.audon.co.uk/mobdus_slim/MOD-8AO.html?gclid=Cj0KCQiA6ozhBRC8ARIsAIh_VC0A-599chaYQIpje6vFT0w8ZlP3sfzkuWxOzE7fpQr4qpHzUNot25oaAk2-EALw_wcB
      This says it can do MODBUS RTU or MODBUS ASCII, so in principle it can communicate with UniPI Neuron - any suggestions/hints for connecting third party devices? At the moment testing out configuring with Mervis - Would like to add some analogue outputs for lighting dimmers.
      Thanks,
      Rob
        TomasKnot last edited by
        In theory it should work the same as any other extension we have, though we cannot guarantee it, since some devices deviate from the standard protocol in one way or another. Either way you will need to create a custom ModBus map, whether you are using Evok, Mervis or something else.
