    wifi configuration problems
    Scheduled Pinned Locked Moved Unipi 1 - HW Q&A
    2 Posts 2 Posters 1.7k Views 1 Watching
    • K
      ketolone
      Hello to all
      I started using UNIPI 1.1 with the image "unipi-neuron-mervis-os-2018-09-14_v1.7-beta" but I can not configure the raspberry wi-fi
      I connect via SSH "unipi: unipi.technology" is ok!
      instead if I want to connect with "root: unipi" tells me that the password is wrong!
      I can help you
      Thank you
      • Martin KudláčekM
        Martin Kudláček @ketolone
        Hello @ketolone,
        the root login is disabled by default as a security measure. To perform commands as a superuser, login as user unipi and use sudo before any command or switch to the superuser completly with sudo bash.
        I believe this was the cause of your confguration problems.
