    UniPi Neuron - UniPi-Mervis-OS-2018-08-03_v1.7-BETA and ssh
    Neuron Series
    • B
      bartekwoznica last edited by
      I've just burned last image UniPi-Mervis-OS-2018-08-03_v1.7-BETA to SD card and try to run it.
      MarvisOS is working fine (my solution was succesfully deplyed, as well Web site) but I cannot login
      via SSH or telnet. Every connection on port 22 is refused. IS sshd port changed or I have to turnon sshd in some way?
        Martin Kudláček @bartekwoznica last edited by
        Hello @bartekwoznica,
        since image version 1.7 the SSH is disabled by default as a security measure. You can enable it by creating a file named "ssh" in the "boot" partition of the SD card. This process is identical to the Raspbian's: https://hackernoon.com/raspberry-pi-headless-install-462ccabd75d0
