Humidity sensor for unipi that can work with evok or owfs ?
@tenallero Evok is actually using owfs - https://github.com/UniPiTechnology/evok/blob/master/evok/owclient.py#L232
So evok is basically retransmitting the data between OWFS and its APIs... BUT there is a lot of code to adopt OWFS to the evok infrastructure to be able to provide it to the APIs :)
Tomas,
Thanks.
This is good point to me to start studying.
If I understand well ...to be able to use owfs, I don´t need to change evok code. I need to code at owfs layer? -
@tenallero You can use owfs completely separately from evok. You can also use owhttpd which provides the whole 1wire network on HTTP basis..
@tomas_hora said in Humidity sensor for unipi that can work with evok or owfs ?:
@tenallero You might have noticed the recent extensive work on Evok https://github.com/UniPiTechnology/evok/commits/master. The humidity sensors are also currently in development and should be included in the master branch next week if everything goes well.
There is always a DIY solution, eg. OWFS.
New sensors finaly arrived.......1-WIRE-T-O indoor/outdoor & 1-WIRE-T-R-EVAPCB-BOX.
But where is humidity ? -
@blacksoll Those products are only temperature sensors. If you are looking for humidity sensor, take a look at our offer of the Sedtronic products: https://www.unipi.technology/sedtronic-1-wire-sensor-p67?categoryId=3
