    How to update the EVOK API?
      d00773 last edited by
      Hello
      i'am running API 2.0.5a with unipi 1.1 Board.
      It was installed by the install-evok.sh script.
      I'd like to update to current Version (2.0.5.e).
      How to do it the best?
      Michael
        Hi @d00773!
        Unfortunately there is no simple way of updating EVOK, as changes in the installation script cannot be easily applied retroactively to old installations. However for smaller updates you can replace the files in /opt/evok with the files in the evok directory of the latest release.
        Otherwise you will have to use a clean new image. We are working on a more modular installation procedure, but it most likely will not be backwards compatible.
