Set CNT of DI
I am trying so set the counter of a DI after certain events happen.
For that I need a Library Box in Fupla which after its get enabled puts a dword input straight to output ?
Help is very much appreciated, thanks
Christoph
Hi @csacher!
You can use the SEL block for this.
Bring the output back into in0 via a variable and the new value into in1, with g acting as enable/disable
Kind Regards
