    Running UniPi on reboot
    UniPi 1 - First Generation
    • E
      Eanna last edited by
      Hi
      I'm just wondering is there a way to run the unipi the whole time.
      I've tried all of the ways online but none seems to work
        Could you just mention what do you mean by UniPi?
        I.e. is it a program, device, etc.
        EVOK should run on reboot always, as does Mervis and CODESYS
        • E
          trying to run the unipi 1.1 on reboot through python code
            TomasKnot last edited by
            I still don't quite understand what you are trying to do. EVOK should run automatically if you don't make any changes to the contrary.
            E 1 Reply Last reply Reply Quote 0
            • E
              Eanna @TomasKnot last edited by
              @TomasKnot I want the UniPi to run the software loaded on it once the Pi and UniPi are powered up
                @Eanna
                You can use e.g the rc.local file, as with standard Linux. Another option would be systemctl, which is what we use ourselves, but it is more complex.
                See: https://www.raspberrypi.org/documentation/linux/usage/rc-local.md
                This question isn't really related to EVOK though, so I've moved this to the UniPi 1.1 section.
