    autorun jar file
      jens1238 last edited by
      Hello ,
      I have unipian installed on my unipi. Now i want to autorun a jar file when the system boots up.
      Normally on raspbian you can change that in the /etc/rc.local , but on the unipian os there is no such file.
      Dus anyone know what i must use ?
        TomasKnot last edited by
        You should be able to create the file yourself. Note that you will need to set the rights on it to be executable (chmod help).
          is there not a file already ?
            There should be, but if there isn't you can create it. As you say there isn't, you will need to create it.
