    UniPi changing relay state
    Unipi 1 - First Generation
    4544
    • E
      Eanna last edited by
      Hi
      Sorry I'm new to this and trying to set up the UniPi with my raspberry Pi but i cant get the relays to change state. I cant see what im doing wrong I've followed all instructions.
      Any help greatly appreciated
      Thanks.
        TomasKnot last edited by
        Could you describe what exactly are you using to change the relay state, i.e. which software and image?
        You may find it easiest to use Mervis, at least to try things out.
        • E
          Eanna last edited by tomas_hora
          Hi Tomas
          Im using Python to programme it.
          this is my code:
          payload = "{1}"
          conn.request("GET", "/json/relay/%7Bcircuit%7D", payload)
          res = conn.getresponse()
          data = res.read()
          print(data.decode("utf-8"))
          ##payload = "{\"1\":\"0\",\"timeout\":\"0\",\"mode\":\"string (optional)\",\"pwm_freq\":\"2000",\"pwm_duty\":\"50\",\"alias\":\"string (optional)\"}"
          ##headers = { 'content-type': "application/json" }
          ##conn.request("POST", "/json/relay/%7Bcircuit%7D", payload, headers)
          ##res = conn.getresponse()
          ##data = res.read()
          ##print(data.decode("utf-8"))
          payload = "{2}"
          data = res.read()
          ##payload = "{\"2\":\"0\",\"timeout\":\"0\",\"mode\":\"string (optional)\",\"pwm_freq\":\"2000",\"pwm_duty\":\"50\",\"alias\":\"string (optional)\"}"
          ##data = res.read()
          I have the changing state code commented out because its giving me errors.
            You need to replace "%7Bcircuit%7D" with e.g. 1_01, or whichever circuit you wish to use. The %7B%7D is caused by the api-docs interface escaping characters '{' and '}', which is meant as a hint for the implementation, to be replaced by the user.
            You can get a list of circuits and device types present by calling/visiting "YOUR-NEURON-IP:PORT/rest/all", sans the quotes and substituting the IP and port for proper values.
            I hope this helps, please do write if you have further issues.
            E 2 Replies Last reply Reply Quote 0
            • E
              Eanna @TomasKnot last edited by
              @TomasKnot have you any examples of the code? I cant find any online that I can understand.
              • E
                How do I know which circuit is numbered in which way?
                Is there examples online?
                • E
                  @TomasKnot said in UniPi changing relay state:
                  Hi Tomas
                  Im using the unipi 1.1. does that still work with the
                  "YOUR-NEURON-IP:PORT/rest/all" ?
                  thanks again
                    Yes, it should work for the UniPi 1.1 as well. You can simply go to e.g. 192.168.1.146:80/rest/all via a standard browser, to see the available devices.
                    You can look into the source code for the website GUI if you want to see an example of using the rest/json API in practice.
                    E 1 Reply Last reply Reply Quote 0
                    • E
                      @TomasKnot
                      Should that ip address work for all or should i use the pi's ip address?
                        You'll have to use your own ip address of course, hence the e.g.
