    SOAP request
    • P
      Patrik last edited by
      I am new here and I am trying to SOAP communication using soapUI. I use latest evok, uni pi 1.1 and my point is, how do I know what parameters should I pass as parameters in soap request in soapUI? image
        Device types come from the following list (and otherwise correspond to the device path in the Rest API):
        'relay',
        'input',
        'ai',
        'ao',
        'ee',
        'sensor',
        'i2cbus',
        'adchip',
        'owbus',
        'mcp',
        'gpiobus',
        'pca9685',
        'ds2408',
        'unipi2',
        'uart',
        'neuron',
        'board',
        'misc_output',
        'led',
        'watchdog',
        'register',
        'wifi',
        'light_channel',
        'light_device'
        and the "circuit" is the device name as specified in the configuration file.
        As an example for UniPi 1.1:
        <soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:unip="http://192.168.1.146:8081/UniPiQueryService">
           <soapenv:Header/>
           <soapenv:Body>
              <unip1:SoapQueryInputList xmlns:unip1="http://127.0.1.1:8081/UniPiQueryService">
                 <!--1 or more repetitions:-->
                 <single_query>
                    <device_circuit>1</device_circuit>
                    <device_type>relay</device_type>
                 </single_query>
              </unip1:SoapQueryInputList>
           </soapenv:Body>
        </soapenv:Envelope>
        An example for setting relays:
        <soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:unip="http://127.0.1.1:8081/UniPiCommandService">
           <soapenv:Header/>
           <soapenv:Body>
              <unip:SoapCommandInputList>
                 <single_command>
                    <property_item>
                       <property_name>value</property_name>
                       <property_value>"0"</property_value>
                    </property_item>
                 </single_command>
                 <single_command>
                    <device_circuit>2</device_circuit>
                    <property_item>
                       <property_value>"1"</property_value>
                    </property_item>
                 </single_command>
                 <single_command>
                    <device_circuit>3</device_circuit>
                    <property_item>
                    </property_item>
                 </single_command>
              </unip:SoapCommandInputList>
           </soapenv:Body>
        </soapenv:Envelope>
        We'll try to provide the examples in the documentation in the next EVOK release.
