    Error while changing Analog input State
      christophebler last edited by
      Hello
      We are triyng to set up
      We are trying to set up a UniPi Neuron S103 with a Sx50 Extension in mA Mode.
      Setting the state over the configuration webpage does return an error.
      So we tried to setup over curl with the same error message.
       curl --request POST   --url http://127.0.0.1:8080/json/analoginput/UART_15_2_01   --header 'content-type: application/json'
      --data '{"mode":"Current", "range":"20.0"}
      {"status": "success", "data": {"errors": "integer out of range for 'H' format code"}}
      Do you have a idea how to fix this?
      Christoph
        It looks like there's an error in the device definition file parser for the AI on xS50. I have now fixed this on the latest GitHub master, but it may take a while to percolate to all of our image distributions.
        If possible I would recommend using the manual Github installation process; if this isn't an option then you may have luck with replacing all ".py" files in /opt/evok with files from "evok" directory on the Github repository linked above.
          Thank you a lot for your help.
          Reinstalling the latest version vorm github EVOK version worked fine.
          kind regards
          Christoph
            Glad you got it working!
            This should now be fixed in our latest opensource image and EVOK release as well.
