    Add value based on time?
    2 Posts 2 Posters 1.7k Views
    • I
      Iogo
      Is it possible, and how, to add a value to a variable after a certain time perioid passes?
      For example I would like to add a value to variable, after each second.
      This is for counting kj/s and after a 24h perioid passes convert kj/s to kwh and add this to another variable. This is for energy measurement
        TomasKnot
        You can do this easily with a simple function block, specifically Integer Scheduler (T19), or Bool Scheduler (T17). Signal from these can be used to trigger a function block which sums the value from a counter to some stored value, and the nulls the counter afterwards.
        I recommend looking through some online tutorials on function block diagrams (FBDs) and structured text (ST), as well as thoroughly reading the "help" topics in the IDE (press F1).
