    No handlers could be found for logger "websocket"
    3238
    • S
      seecosmea last edited by tomas_hora
      Good morning,
      since connecting a new sensor to the 1-Wire network, getting the following error message „No handlers could be found for logger "websocket"“ via LXT Terminal.
      I use the following python 2.7 program:
      #!/bin/bash
      import websocket
      import json
      url = "ws://127.0.0.1:88/ws"
      def on_message(ws, message):
         obj = json.loads(message)
         dev = obj['dev']
         circuit = obj['circuit']
         value = obj['value']
         print message
      def on_error(ws, error):
         print error
      def on_close(ws):
         print "Connection closed"
      #receiving messages
      ws = websocket.WebSocketApp(url, on_message = on_message, on_error = on_error, on_close = on_close)
      ws.run_forever()
      #sending messages
      ws = websocket.WebSocket()
      ws.connect(url)
      ws.send('{"cmd":"set","dev":"relay","circuit":"3","value":"1"}')
      ws.close()
      The EVOK log having following message:
      AttributeError: 'DS2438' object has no attribute 'sensor_dev'
      2018-01-14 08:55:54,139 - evok - ERROR - Error in config section 1WINPUT_23 - 'DS2438' object has no attribute 'sensor_dev'
        File "/opt/evok/config.py", line 221, in create_devices
          sensor = (Devices.by_int(SENSOR, sensor)).sensor_dev
      I appriciate your assitance.
        Hi @seecosmea,
        Could you post your config file? It seems like your 1Wire-DI is connected to a simple DS2438 sensor.
        I don't immediately see what's exactly the issue aside from this, and it would help track it down.
        • S
          Good morining again,
          pls note that I do not have anymore messsages inside the EVOK log, pls find my modified config file below. But I still have the problem that I do not receive any JSON strings from my DS2438 sensors via above mention Python program in order to receive the infos via WS.
          I could get the JSON string only via wget but not via python ws - Here the string from my new CO2 Sensor:
          {"vad": "1.23", "vdd": "5", "circuit": "2656DC84000003B7", "time": 1515692607.33644, "temp": "4.82031", "interval": 15, "typ": "DS2438", "lost": false, "dev": "temp", "humidity": 39.25448718301667}
          Here my string from the new temp & humidity sensor:
          [MAIN]
          config_version = 2.4
          use_experimental_api = False			; Currently in Alpha - known issues
          regenerate_api_docs = False				; Active only with the experimental API setting
          log_level = ERROR   					; One of INFO, DEBUG, WARNING, ERROR, CRITICAL
          log_file = /var/log/evok.log			; Log file to use; will be cleared on boot
          port = 8080								; !!! Internal API port - only change if you are certain you know what you are doing; FOR OUR WEB INTERFACE THE PORT SHOULD BE CHANGED IN "/etc/evok-nginx.conf" INSTEAD !!!
          ;modbus_port = 0
          ;modbus_address = *
          webhook_enabled = False					; Enables webhook notification - see e.g. https://sendgrid.com/blog/whats-webhook/
          webhook_address = http://127.0.0.1:80   ; Put your server endpoint address here (e.g. http://123.123.123.123:/wh )
          webhook_device_mask = ["input","wd"]	; List of device types to notify on (written as a JSON list) - adding AI will generate a large amount of messages!
          webhook_complex_events = False			; EVOK will send POST requests with the same data as WebSocket, rather than an empty GET request
          wifi_control_enabled = False			; !!! REQUIRES THE UNIPIAP WIFI CONTROLLER TO BE INSTALLED !!! Will allow evok to control the internal Neuron wifi
          soap_server_enabled = False				; Enables the simple SOAP server; use only if you need the functionality
          soap_server_port = 8081					; !!! IF SOAP SERVER IS ENABLED, THIS PORT NEEDS TO BE UNIQUE (i.e. different from the port setting above) !!!
          [OWBUS_1]
          owbus = --i2c=/dev/i2c-1:ALL     		; scanned bus (--i2c=/dev/i2c-1:ALL or localhost:2122 or 'u' for USB dongle)
          interval = 3          					; [s] default sensor reading
          scan_interval = 300    					; [s] how often is made searching
          ;[SENSOR_1]	     						; onewire thermometer
          ;bus = 1		     					; link to OWBUS_X
          ;address = 28527B930500001F
          ;type = DS18B20
          ;interval = 1
          [I2CBUS_1]
          busid = 1     							;[integer] id of bus /dev/i2c-X
          ;[EPROM_1]								;EPROM device will not be used anymore, eprom should be handled by kernel module
          ;i2cbus = 1
          ;address = 0x50
          ;size = 256
          [MCP_1]
          i2cbus = 1								; link to I2CBUS_X
          address = 0x20							; i2c address
          [RELAY_1]
          mcp = 1									; link to MCP_X
          pin = 7
          [RELAY_2]
          pin = 6
          [RELAY_3]
          mcp = 1
          pin = 5
          [RELAY_4]
          mcp = 1
          pin = 4
          [RELAY_5]
          mcp = 1
          pin = 3
          [RELAY_6]
          mcp = 1
          pin = 2
          [RELAY_7]
          mcp = 1
          pin = 1
          [RELAY_8]
          mcp = 1
          pin = 0
          ;[AICHIP_1]
          ;i2cbus =1
          ;address = 0x68
          ;[AI_1]
          ;chip=1
          ;channel=0
          ;bits=18
          ;gain=1
          ;;correction = 5.558737622
          ;;correction = 5.564920867
          ;corr_rom = 1
          ;corr_addr = 0xf0
          ;interval=2
          ;[AI_2]
          ;chip=1
          ;channel=1
          ;bits=18
          ;gain=1
          ;corr_rom = 1
          ;corr_addr = 0xf4
          ;interval=1
          [GPIOBUS_1]
          [AO_1]
          gpiobus = 1
          frequency = 100
          [DI_1]
          gpiobus = 1
          pin=4
          debounce = 0
          ;Enable counting on rising/falling edge or disable it
          ;By default(or parameter not present) this function is disabled
          ;Can be turned on on all on-board digital inputs (not inputs on 1Wire or other extensions)
          ;counter_mode = rising
          ;counter_mode = falling
          ;counter_mode = disabled
          [DI_2]
          gpiobus = 1
          pin=17
          debounce = 0
          [DI_3]
          gpiobus = 1
          pin=27
          debounce = 0
          [DI_4]
          gpiobus = 1
          pin=23
          debounce = 0
          [DI_5]
          gpiobus = 1
          pin=22
          debounce = 0
          [DI_6]
          gpiobus = 1
          pin=24
          debounce = 0
          [DI_7]
          gpiobus = 1
          pin=11
          debounce = 0
          [DI_8]
          gpiobus = 1
          pin=7
          debounce = 0
          [DI_9]
          gpiobus = 1
          pin=8
          debounce = 0
          [DI_10]
          gpiobus = 1
          pin=9
          debounce = 0
          [DI_11]
          gpiobus = 1
          pin=25
          debounce = 0
          [DI_12]
          gpiobus = 1
          pin=10
          debounce = 0
          ;[DI_13]
          ;gpiobus = 1
          ;pin=31
          ;debounce = 0
          ;[DI_14]
          ;gpiobus = 1
          ;pin=30
          ;debounce = 0
          ;Example of 8xRelay extension module addon (EMO-R8) on address 0x21
          ;[MCP_2]
          ;i2cbus = 1
          ;address = 0x21
          ;[RELAY_9]
          ;mcp = 2
          ;pin = 7
          ;[RELAY_10]
          ;mcp = 2
          ;pin = 6
          ;[RELAY_11]
          ;mcp = 2
          ;pin = 5
          ;[RELAY_12]
          ;mcp = 2
          ;pin = 4
          ;[RELAY_13]
          ;mcp = 2
          ;pin = 3
          ;[RELAY_14]
          ;mcp = 2
          ;pin = 2
          ;[RELAY_15]
          ;mcp = 2
          ;pin = 1
          ;[RELAY_16]
          ;mcp = 2
          ;pin = 0
          ;Example of Analog Output extension module EMO-Ao4/12
          ;[PCA9685_1]
          ;i2cbus = 1
          ;address = 0x40
          ;frequency = 400
          ;[AO_2]
          ;pca = 1
          ;channel = 0
          ;[AO_3]
          ;pca = 1
          ;channel = 1
          ;[AO_4]
          ;pca = 1
          ;channel = 2
          ;[AO_5]
          ;pca = 1
          ;channel = 3
          ;Example of 1W-4R/4DI extension module, 1W-8R is almost the same just replace inputs with relays
          ; - First map a new 1Wire sensor with appropriate address, type, and interval
          ; - Can use both SENSOR or 1WDEVICE syntax
          ; - Reading interval is crucial to achieve expected performance, default interval is 15s
          [1WDEVICE_2]
          bus = 1
          address = 3AFF60340000009E
          type = DS2413
          interval = 1
          [1WRELAY_10]
          sensor = 2
          pin = 0
          [1WINPUT_20]
          sensor = 2
          pin = 1
          [1WDEVICE_3]
          bus = 1
          address = 3A4D6B3400000087
          type = DS2413
          interval = 1
          [1WRELAY_11]
          sensor = 3
          pin = 0
          [1WINPUT_21]
          sensor = 3
          pin = 1
          [1WDEVICE_4]
          bus = 1
          address = 3AC3323400000018
          type = DS2413
          interval = 1
          [1WRELAY_12]
          sensor = 4
          pin = 0
          [1WINPUT_22]
          sensor = 4
          pin = 1
          [1WDEVICE_5]
          bus = 1
          address = 2656DC84000003B7
          type = DS2438
          interval = 1
          [1WINPUT_23]
          sensor = 5
          [1WDEVICE_6]
          bus = 1
          address = 265ADC84000003CA
          type = DS2438
          interval = 1
          [1WINPUT_23]
          sensor = 6
          ;[1WRELAY_11]
          ;sensor = 2
          ;pin = 1
          ;[1WRELAY_12]
          ;sensor = 2
          ;pin = 2
          ;[1WRELAY_13]
          ;sensor = 2
          ;pin = 3
          ;[1WINPUT_20]
          ;sensor = 2
          ;pin = 4
          ;[1WINPUT_21]
          ;sensor = 2
          ;pin = 5
          ;[1WINPUT_22]
          ;sensor = 2
          ;pin = 6
          ;[1WINPUT_23]
          ;sensor = 2
          ;pin = 7
          • S
            Liegt mein Problem eventuell bei dem Python websocket / JSON module (import websocket - import json)
            • S
              Good morning, could it be that the problem is related to the Python websocket / JSON module (import websocket - import json). I do receive still the error message : No handlers could be found for logger "websocket" if I start the program in LXTerminal: sudo python /home/pi/py4.py
              I receive after starting the DS18B20 temperature strings but not any JSON strings from DS2438 via the python program above. I would like to receive the JSON strings in my Gambas main program from that python script. Could you pls be so kind to assist....
              tks in advance
              • S
                Good morning again,
                could you pls be so kind to let me know if I could expect any answer at all, I do have sill the sam problem that I receive the DS18B20 temperature strings but not any JSON strings from DS2438 via the python program above.
                I checked the UniPi forum every moring with the hope to get new hints on present subject but nothing at all. I guess that my problem is not your area of responsibility ?
                tks in advance
                  TomasKnot last edited by
                  The error "No handlers could be found for logger "websocket"" is from your client library, it means you haven't registered an output logger (appropriately enough).
                  I am not sure what's causing the issue with the DS2438. Do you get any 1wire messages at all? Or indeed any other.
                  • S
                    seecosmea @TomasKnot last edited by
                    Good day,
                    I do receive all JSON stings from my DS18B20 temperatur sensors and from my DS2413 (Wire Dual Channel Addressable Switch) but I do not receive any strings from DS2438 at moment. I could get the JSON string via the wget method or via http://127.0.0.1:88/rest/all.
                    Do you have any idea on how I could get the strings via the above mentioned python program via Websocket; I actually do not understand why I do not receive the DS2438 strings...
