    M203 clean evok install not working
    1
      rob last edited by
      I bought an M203, and flashed the official UniPian Neuron OS image available here
      Trying to access the web interface showed an empty list of inputs and outputs, nothing was working:
      alt text
      So I tried an apt-get dist-upgrade followed by a manual installation of latest evok 2.0 as per instructions available here
      Rebooted, I get the same result.
      Here is the log I get when launching evok manually as instructed in the debug section of the documentation:
      pi@M203-sn100:/etc $ sudo python /opt/evok/evok.py
      [I 180106 15:58:02 config:66] eprom: UniPi Neuron M203 version: 1.0 serial: 0x64
      [I 180106 15:58:02 evok:1640] Starting using config file /etc/evok.conf
      [I 180106 15:58:02 config:78] YAML Definition loaded: CUSTOM MODBUS DEVICE.yaml, type: 3, definition count 0
      [I 180106 15:58:02 config:78] YAML Definition loaded: S10x.yaml, type: 3, definition count 1
      [I 180106 15:58:02 config:78] YAML Definition loaded: M30x.yaml, type: 3, definition count 2
      [I 180106 15:58:02 config:78] YAML Definition loaded: M20x.yaml, type: 3, definition count 3
      [I 180106 15:58:03 config:78] YAML Definition loaded: L20x.yaml, type: 3, definition count 4
      [I 180106 15:58:03 config:78] YAML Definition loaded: M50x.yaml, type: 3, definition count 5
      [I 180106 15:58:03 config:78] YAML Definition loaded: xS30.yaml, type: 3, definition count 6
      [I 180106 15:58:03 config:78] YAML Definition loaded: L51x.yaml, type: 3, definition count 7
      [I 180106 15:58:03 config:78] YAML Definition loaded: L40x.yaml, type: 3, definition count 8
      [I 180106 15:58:04 config:78] YAML Definition loaded: xS40.yaml, type: 3, definition count 9
      [I 180106 15:58:04 config:78] YAML Definition loaded: M40x.yaml, type: 3, definition count 10
      [I 180106 15:58:04 config:78] YAML Definition loaded: L30x.yaml, type: 3, definition count 11
      [I 180106 15:58:04 config:78] YAML Definition loaded: L50x.yaml, type: 3, definition count 12
      [I 180106 15:58:04 config:78] YAML Definition loaded: M10x.yaml, type: 3, definition count 13
      [I 180106 15:58:05 config:78] YAML Definition loaded: xS50.yaml, type: 3, definition count 14
      [I 180106 15:58:05 config:78] YAML Definition loaded: DALI.yaml, type: 3, definition count 15
      [I 180106 15:58:05 config:78] YAML Definition loaded: xS10.yaml, type: 3, definition count 16
      [I 180106 15:58:05 config:78] YAML Definition loaded: evok-alias.yaml, type: 2, definition count 0
      [I 180106 15:58:05 evok:1704] HTTP server listening on port: 8080
      [I 180106 15:58:05 modbusclient_tornado:125] SPI client started
      [I 180106 15:58:05 neuron:173] Reading SPI boards
      [I 180106 15:58:05 neuron:188] No board on SPI 1
      [I 180106 15:58:05 neuron:188] No board on SPI 2
      [D 180106 15:58:05 owclient:376] Entering 1wire loop
      [I 180106 15:58:05 neuron:188] No board on SPI 3
      [E 180106 15:58:05 config:358] Invalid device circuit number 1_01
      File "/opt/evok/config.py", line 353, in add_aliases
      dev_obj = Devices.by_int(dev_pointer["dev_type"], dev_pointer["circuit"])
      File "/opt/evok/devices.py", line 67, in by_int
      raise Exception('Invalid device circuit number %s' % str(circuit))
      Exception: Invalid device circuit number 1_01
      [E 180106 15:58:05 config:358] Invalid device circuit number 1_02
      Exception: Invalid device circuit number 1_02
      [E 180106 15:58:05 neuron:227] 'NoneType' object has no attribute 'do_scan'
      File "/opt/evok/neuron.py", line 225, in scan_boards
      yield self.modbus_cache_map.do_scan()
      AttributeError: 'NoneType' object has no attribute 'do_scan'
      [E 180106 15:58:06 neuron:227] 'NoneType' object has no attribute 'do_scan'
      [E 180106 15:58:07 neuron:227] 'NoneType' object has no attribute 'do_scan'
      [I 180106 15:58:07 web:2063] 101 GET /ws (::1) 6.00ms
      [D 180106 15:58:07 evok:169] New WebSocket client connected
      [I 180106 15:58:07 web:2063] 304 GET /rest/all (::1) 6.26ms
      ^C[I 180106 15:58:07 evok:1779] Shutting down
      Is there something wrong with my hardware? It seems to me the RPI can not communicate with the internal plc boards.
      Or is it a configuration mistake? What could I possibly have done wrong?
      I'll be very grateful to anyone who could shed some light.
      Thanks!
      Rob
      R 1 Reply Last reply Reply Quote 0
        rob @rob last edited by
        Quick update:
        I repeated the Evok installation as per the instructions above on a clean vanilla raspbian stretch image taken from the official raspberry pi repo (not the UniPi customized one) and everything works fine.
        Thus - there seems to be some misconfiguration in the official UniPi image, at least when used with M203: beware.
        Rob
