    Adding Extensions to Evok
    • B
      Boernsman last edited by
      I've a hard time to add an extension to evok, I tried different settings in the /etc/evok.conf - no success. Found also no documentation about the extensions and how to add them without using mervis.
      • B
        To be more specific I use Raspbian GNU/Linux 9.1 (stretch) with a Neuron L40x and a xS30 Extension.
        /etc/evok.conf:
        ;[EXTENSION_1]
        device_name = xS30
        modbus_uart_port = /dev/extcomm/0/0
        allow_register_access = False
        scan_frequency = 2
        scan_enabled = True
        DIP switches on the extension are all OFF, cable length 30cm
        U 1 Reply Last reply Reply Quote 0
        • U
          unix @Boernsman last edited by
          @Boernsman
          Hi
          use
          [EXTENSION_1]
          global_id = 2
          device_name = xS30
          neuron_uart_circuit = 1_01
          allow_register_access = True
          address = 15
          scan_frequency = 2
          scan_enabled = True
          baud_rate = 19200
          parity = N
          stop_bits = 1
          Regards
          • B
            Thanks, worked out for me
